trouble having car lock
mathis_53
Posted: October 24, 2010 at 2:45 PM / IP Logged
I have a 2000 impala and i have installed a security system. and the only thing it won't do is lock.i believe it has something to with diode isolating. I have no clue on how this is done and need help. where do i purchase this and which door triggers do i use.
2000 Chevy Impala
Juan
mathis_53
Posted: October 24, 2010 at 2:57 PM / IP Logged
Im a rookie at this and any help would be appreciated
Juan
Platinum - Posts: 13,726
Posted: October 24, 2010 at 3:02 PM / IP Logged
According to Audiovox, a 470 ohm resistor is required for door lock.  Did you use one?
mathis_53
Posted: October 24, 2010 at 4:57 PM / IP Logged
no i dont really have a clue what that is but could you give m a better idea and where to get one?
Juan
mathis_53
Posted: October 24, 2010 at 5:06 PM / IP Logged
im purchasing one now.. what would i have to do now
Juan
Posted: October 24, 2010 at 5:33 PM / IP Logged
What wire of the vehicle did you use for unlock?   Did you use a relay?
mathis_53
Posted: October 24, 2010 at 6:12 PM / IP Logged
i did the ORANGE / black for unlock with no relay
Juan
Posted: October 24, 2010 at 6:35 PM / IP Logged
I think you will need to use relays.   Connect them as follows.  12Volts constant to terminal 86 of both relays.  Alarm's lock wire to 85 of the lock relay.  The alarm's unlock wire to 85 of the unlock relay.  Connect terminal 30 of both relays to the ORANGE / Black wire.  Ground terminal 87 of the unlock relay.  Connect the 470 ohm resistor to terminal 87 or the lock relay.  Ground the other end of the resistor.
