viper 5902, 529t module on santa fe
santafe98
Member - Posts: 12
Posted: October 30, 2010 at 11:56 AM / IP Logged
Hey everyone, just in advance thank you for all help, you guys are so informative and helpful whenever I've had problems installing things!! I want to add a module to my Viper 5902 alarm on my 2002 Hyundai Santa Fe, to shut the sunroof when I press arm. I believe the 529T module is the one I need? My sunroof has two functions, UP/DOWN and CLOSE/OPEN for venting or fully opening.
Would I need to buy two 529T modules to control both functions, or is one enough? If it's possible I would like just one module, to automatically close the sunroof, either from fully open or vented when I arm. If I have to use two modules, could I then set it to open/vent from the aux channels as well...? Thanks for reading!
santafe98
Member - Posts: 12
Posted: October 30, 2010 at 11:58 AM / IP Logged
PS in addition, I have a 530T module already installed on the front windows, which controls two windows up/down, would I be able to just buy another one of these and use it to control both sunroof functions for open/close...? just a thought!
Posted: October 30, 2010 at 4:12 PM / IP Logged
You would have to test at the motor and see what happens, i.e. which wire stays neg and which goes hot when you close from either. It should be identical and a 529t should suffice.
