viper 5101 keyless entry
cumminsman1991
Posted: November 20, 2010 at 4:41 PM / IP Logged
Hey guys I have a 2001 dodge ram 2500 diesel. I recently put it a viper 5101 remote starter. I'm having one issue with it. It will not lock or unlock the doors when the ignition is on. It works fine with the ignition off and when the remote start is running the vehicle but with the ignition on no go. I talked to a couple of installers around here with no luck. So if somebody could shed some light on this topic I would appreciate.
Jesse
calijtee1
Copper - Posts: 121
Posted: December 29, 2010 at 12:21 AM / IP Logged
had the same exact prob with a couple dodges dont use the factory keyles entry wires use the factory alarm and disarm wires but u have to five wire reverse polarity the dor lock motors u need two relays for this ..itll do the drivers door perfect then when u get in u can unlock the rest manually
installers do it best. we got the magic hands!
cumminsman1991
Posted: December 29, 2010 at 8:21 AM / IP Logged
I don't have factory keyless entry or alarm. The lock work fine when the ignition is off but when you turn it on the pulse coming out of the module is not there. I used a voltmeter and checked the pulse with the ignition off and the ignition on. Do I have something hooked up wrong?
zerepdivad
Silver - Posts: 605
Posted: December 30, 2010 at 12:57 AM / IP Logged
are you sure you don't have a factory alarm? most of these that i've worked on do have it. I also generally use the disarm/arm wire for locks on chyslers.
A DMM is a beautiful thing.
cumminsman1991
Posted: December 30, 2010 at 8:27 AM / IP Logged
Positive. But you can bypass the vehicle locks all together and check for the 12 volt pulse coming directly out of the module with a voltmeter. The pulse isn't there with ignition on. Which leads me to think i either have a setting wrong a wire not hooked up or something not hooked up correctly. But everything eles work exactally like it is supposed to.
Friday, January 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
