07 lexus es 350
amjpurcell
Posted: November 28, 2010 at 6:20 PM / IP Logged
Help  Installing a nav system in my car it includes the climate controls that display on the nav       problem is I can not find the wire that reads the inside temp. It is a dual temp system so im not sure if there is a RH and LH input . The nav unit will control the AC heat  Fan speed but it does not display the temp unless its full on or full off. Need help
Thanks John
Posted: November 29, 2010 at 6:41 AM / IP Logged
Think you're on a hiding to nothing, it's probably data.
amjpurcell
Posted: December 01, 2010 at 12:22 AM / IP Logged
Thanks, Talked to the MFG they said send it back
