2003 hyundai sonata remote start
danieljaluise
Copper - Posts: 125
Posted: November 28, 2010 at 8:06 PM / IP Logged
Hi, I need a wiring diagram for a 2003 hyundai sonata. Is a bypass needed for this car? If so, which one?
THANKS!
Posted: November 29, 2010 at 6:40 AM / IP Logged
Use the vehicle wiring guide here, it's your friend!
It lists 2002. If that's the same body shape as yours you should have no problems.
tommy...
Gold - Posts: 1,901
Posted: November 29, 2010 at 11:19 PM / IP Logged
WIRE COLOR POLARITY LOCATION
Battery RED (+) IGNITION SWITCH HARNESS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Ignition 2* TEST FOR 2ND... (+) IGNITION SWITCH HARNESS
Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
Key Sense LIGHT GREEN (+) IGNITION SWITCH HARNESS
Tachometer WHITE (AC) AT THE ECM
ON THE 2.4L A/T, TACH IS PIN 3 OF THE 26 PIN CONNECTOR ON THE 2.4L M/T, TACH IS PIN 8 OF THE 12 PIN CONNECTOR ON THE 2.7L TACH IS PIN 17 OF THE 40 PIN CONNECTOR THE ECM IS LOCATED ON THE RIGHT SIDE OF THE GAS PEDAL
Speed Sense BROWN (AC) AT THE ECM
ON THE 2.4L A/T VSS IS PIN 10 OF THE 28 PIN CONNECTOR ON THE 2.4L M/T VSS IS PIN 16 OF THE 22 PIN CONNECTOR ON THE 2.7L VSS IS PIN 22 OF THE 40 PIN CONNECTOR
Parking Lights BROWN / WHITE (+) IN 22 PIN CONNECTOR BEHIND FUSE BOX
Brake Lights LIGHT BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights LIGHT GREEN (+) IN DRIVER'S KICK PANEL
Horn YELLOW/ORANGE (-) AT STEERING COLUMN HARNESS
No by-pass...Hey howie...! Just did one today...Was kind of a blur though(the day that is)...VERY easy car...! Where it says "parking lights in 22 pin  connector behind fusebox"....The harness is just taped to another harness running behind the fusebox...It's not plugged in to anything...Just taped...!
M.E.C.P & First-Class
Posted: November 29, 2010 at 11:34 PM / IP Logged
Give me Korean and Japanese all day long! Simple but quality fixings with Philips head screws, everything's where you expect it to be, logical etc.
God help you when Fiat returns after a 20 year gap unless they vastly improve the build quality and electrical assemblies, oh wait they've taken over Chrysler so no change there in the build quality.
1 Panel, 3 and 4mm hex head bolts, + pozi + Torx and it STILL breaks when you remove it.
They still can't make a steering column cowl that goes back!
