2011 nissan armada using dball
imtfox
Member - Posts: 9
Posted: November 29, 2010 at 4:02 PM / IP Logged
So I have the RS9000 from Code Alarm all hooked up and a DBALL doing my can-bus interfacing. The security bypass, foot brake, and tach all work flawlessly through the DBALL.
The problem is in the Lock/Unlock.
I have programmed the feature #1 to type 2 as per the instructions (for a 2010 anyway). When attempting to unlock through the module, it flashes green 2x indicating it got the signal, it chirps the siren 2x like normal, but the parking lights flash 4x and nothing happens to the locks. Did something change in the 2010 to 2011 years? Do I need to wait for DEI to upgrade the firmware? Do I just need to say screw it and go into the door for the locks?
Any help would be appreciated.
Who's House?? Run's house!!
imtfox
Member - Posts: 9
Posted: November 30, 2010 at 8:59 AM / IP Logged
Just an update: I also noticed this morning when I started the truck that the info center said "Configuration failed because consult is connected. Disconnect consult" but that didn't seem to affect anything feature-wise on the truck. I'm now leaning toward something in the can-bus has changed.
