99 silverado passlock
big_ed5150
Member - Posts: 6
Posted: December 06, 2010 at 4:44 PM / IP Logged
Ok, first off if i'm correct if the 99 silverado has passlock it would show up in the info window on the left side of the cluster correct. we are installing an autopage rs on 99 silverado 4.8 engine, we taped pin 10 for tach unit learned it but when we remote start it tries and then dies. the led light tells us 3 flashes which is tach or voltage. if we set the key in the ignition does the same thing so to our knowledge there is no passlock 2 on it, right. Please help everyone.
"Big" Ed Bausman
General Manager
Advanced Audio/Video
Rogers, Ar
kgerry
Platinum - Posts: 3,455
Posted: December 06, 2010 at 5:20 PM / IP Logged
all 98-up GM trucks have Passlock II .... leaving the key in the IGN will tell you nothing with a PL system..... R code is generated during crank....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
big_ed5150
Member - Posts: 6
Posted: December 06, 2010 at 5:24 PM / IP Logged
ok one question, we can start with key, and while running engage the remote start turn key off and it stays running, wouldn't it shut off if it had passlock 2,,i'm just trying to find out for sure
"Big" Ed Bausman
General Manager
Rogers, Ar
big_ed5150
Member - Posts: 6
Posted: December 06, 2010 at 5:36 PM / IP Logged
even the bare bones silverado with rubber floor no locks etc have it
now one other thing what is the voltage threshold of most remote starts, such as the lowest voltage cause this truck drops to 9.7 when cranking. Just covering all my bases' i do appreciate the help everyone
"Big" Ed Bausman
General Manager
Rogers, Ar
blanx218
Silver - Posts: 654
Posted: December 07, 2010 at 12:06 AM / IP Logged
you definitely need a bypass. a pljx or something similar. when using the stop and go feature the car is already running so it will stay running. passlock or transponder systems only come into play when starting the vehicle. once its running it becomes irrelevant.
are you using voltage sensing? you shouldnt have an issue with the 9.7V. if you do there should be a programming feature or jumper somewhere on the brain to adjust the threshold. if you still have issues you may need to run a tach wire
zerepdivad
Silver - Posts: 605
Posted: December 07, 2010 at 10:44 PM / IP Logged
it has passlock don't fight it. if you just want to be cheap and not use a bypass use your brain, a meter, resistors, and 2 relays and make it happen.
A DMM is a beautiful thing.
