how many subs
Paradigm
Silver - Posts: 284
Posted: February 15, 2011 at 11:07 AM / IP Logged
Why would you even want to run the amp down to 0.5 ohms anyway? That would generate a fair amount of heat that you would have to consider, even if it could go that low. Reread all of your specs and make sure that what you have can do what you want it to - else you will be left disappointed more than likely.
VEHICLE: 2002 GMC Sonoma ZR2
Alpine CDA-7940
AudioControl EQT x2
JL Audio 1000/1
JL Audio 10W6 (originals) x3
Kicker ZR120
Kicker ZR460
Polk GXR-6 x4
Polk GXR-4 x2
oldspark
Gold - Posts: 4,913
Posted: February 15, 2011 at 4:00 PM / IP Logged
I like the vct2610 6kW output.... 2x60A MAXI fuses => what, 1800WRMS maximum? pmpo indeed!
waynesworld42
Member - Posts: 9
Posted: February 15, 2011 at 7:18 PM / IP Logged
  dont have the spec sheet . the person i bought the amp and 1 of the 12s from had it wired down to .5 ohm so i assumed it being a class d amp it could go that low . im gonna try soundstream for spec sheet.  thanks for the imput im gonna have a few dollars rapped up in this so i dont wanna blow it up.
wayne,e;42
waynesworld42
Member - Posts: 9
Posted: March 30, 2011 at 10:58 AM / IP Logged
  not a good amp keeps going into protect mode but maybe its my fault  . if a amp says its 2 and 4 ohm stable does that mean its automaticly 2 ohm stable bridged     my spec sheet doesent say . on the possitive side of things before it goes into protect mode it loud as hell
wayne,e;42
haemphyst
Platinum - Posts: 5,059
Posted: March 30, 2011 at 12:25 PM / IP Logged
If the amp is 2-ohm stable, you can only BRIDGE it into a 4-ohm or higher impedance.
Class D does not mean "low-impedance capable". Class D is an internal operating mode. Class A, Class A/B, and Class D are all common "modes" of operation for audio frequency amplifiers.
Dude... PLEASE, before you burn your car to the ground, PLEASE talk with someone that can help you install this gear correctly. From your posts, it sounds to me like you know very little to nothing about amplifiers, impedance, enclosures... indeed ALL aspects of safe car audio installation... I am not saying tht you can't LEARN them, but I am asking that you get help with your first system, until you understand a little more, and can properly wire your equipment.
BEST case, I see you going broke buying fuses... WORST case, I see you not ever being able to get car insurance again, because you won't be able to afford it after this claim.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
