using a key fob while the key is on.
cdebcoleman
Member - Posts: 9
Posted: December 28, 2010 at 11:26 PM / IP Logged
Installing an Audiovox PRO9232b add-on security system to a 2006 Dodge Ram 1500 with factory keyless entry. Its a cheap/basic alarm and an easy install, however in order to access the programming modes I have to have the key on. With the key on factory transmitters won't work, so I can't change any of the settings. This kit relies on the factory transmitters and have no aftermarket ones. Any ideas?
Chris Coleman
tonanzith
Gold - Posts: 603
Posted: December 29, 2010 at 12:07 AM / IP Logged
Try using the door lock switch instead.
Gary Sather
cdebcoleman
Member - Posts: 9
Posted: December 29, 2010 at 7:44 AM / IP Logged
Tried the power lock switch already. Didn't work.
Chris Coleman
Twelvoltz
Platinum - Posts: 2,384
Posted: December 29, 2010 at 8:19 AM / IP Logged
Temporarily hook up a momentary switch to the wire that monitors the actuator leg. Have you tried it with the door shut, or the other remote that came with the truck?
flobee4
Silver - Posts: 585
Posted: December 29, 2010 at 8:39 AM / IP Logged
I just did a 2007 Ram the other day, The key that is in the ignition will not work for keyless. While you have 1 key in the ignition use your spare key to control keyless functions. The car disables the keyless function on the key in the ignition but doesn't disable the keyless function on your second key.
cdebcoleman
Member - Posts: 9
Posted: December 29, 2010 at 8:53 AM / IP Logged
Thanks for the replies guys. The customer didn't have another key fob. I just simulated the ignition by manually hooking into a constant 12v source and it did the trick. Don't know why I didn't think of that earlier.
Chris Coleman
