oem ford not functioning
little fish
Posted: January 09, 2011 at 11:43 PM / IP Logged
I just got a 06 F150 FX4, it had an aftermarket unit install that was crap and installed poorly. I had access to a AVIC-XD1 form a 07 edge I tried to install with the Facory wiring, all the connections seem the same and fit perfectly. It powers up, I hear the CD tray moving, the FORD logo come on the screen then....nothing operatesbut the CD load and eject.
Since that didn't work I re-installed the Original 6cd/mp3 premium system, I get the same result. Power, cd tray moves then..nothing. What could be causing this problem. Could it be a ground issue.
There are 3 connections, 24 pin, 16 pin, and 8 pin. What should I try?
Newbie
resquchas
Copper - Posts: 93
Posted: January 11, 2011 at 12:42 PM / IP Logged
If it had a "crappy" install that you removed then you can not really be sure what happened at the time of that install. You may need to do some detective work to find out what wires may or may not be compromised using a DMM
The RIGHT way is the ONLY way.
yimke
Copper - Posts: 417
Posted: January 11, 2011 at 5:52 PM / IP Logged
Your ACC wire is not out-putting any voltage. Check the fuses.
resquchas
Copper - Posts: 93
Posted: January 11, 2011 at 8:19 PM / IP Logged
No ACC wire sounds good to me. The way it is acting is though it is not getting the message that it should be ON.
little fish
Posted: January 11, 2011 at 11:20 PM / IP Logged
I checked the fuses when I installed. Turns out someone pulled a fuse and didn't put a new one in. Hard to tell at first glance. I had to check with the owners manual all the fuses and locations. Everything is working fine now.
Thanks for the help!
Newbie
