viper 5901
gregbbb
Copper - Posts: 82
Posted: February 13, 2011 at 9:42 PM / IP Logged
Hi
I am installing a viper 5901 and the dome light supervision only shoes (-) ALL THE TIME HELP!!
itsyuk
Silver - Posts: 505
Posted: February 14, 2011 at 3:06 AM / IP Logged
did you use a relay for the domelightsupervision?
if you didnt use a relay, you may have blown the circuit. the DLS wire can only ground a 200ma or less relay coil.
what vehicle, and how did you wire the DLS?
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
gregbbb
Copper - Posts: 82
Posted: February 14, 2011 at 10:15 AM / IP Logged
2010 Ford edge I used the positive dome light wire in the car and I did use a relay its allways on right out of the box.
itsyuk
Silver - Posts: 505
Posted: February 16, 2011 at 11:01 PM / IP Logged
if the DLS wire from the alarm shows ground all the time with nothing hooked to it, it is defective.
i would only test it with a meter.
using a test light (reverse or back feed testing) might damage it if the light draws a very heavy load on the output.
yuk
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
