2002 Chevrolet Trailblazer Wiring, Alarm/RS/Stereo
orionmeades
Member - Posts: 37
Posted: April 23, 2003 at 7:24 PM / IP Logged
hey everyone,
  if anybody could help i need the wiring diagram for a 2002 trailblazer...im hooking up an alpine 8063 security alarm with power door locks and power windows...i want to add remote start to it also but havent made up my mind which product i want to use for the remote start module...dont think alpine makes one ...if anyone could help i will be very greatful...
thanks
   orion
Platinum - Posts: 12,488
Posted: April 23, 2003 at 8:38 PM / IP Logged
Use the PLDATA bypass module along witht he GMDL1 door lock interface module. Here is the wiring colors that you will need:
|              12V|red  (x2)           |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|use GMDL1|   |                            |
|     POWER UNLOCK|     |   |                            |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |relay box under rear seat   |
| PARKING LIGHTS +|brown               |   |driver kick panel           |
| PARKING LIGHTS -|gray/black          |   |headlight switch            |
|       HEADLIGHTS|white               |-  |headlight switch            |
|     DOOR TRIGGER|gray/black          |+  |underdash light             |
| DOME SUPERVISION|comes on with disarm|   |                            |
|  TRUNK/HATCH PIN|pink/black *1       |-  |liftgate module             |
|         HOOD PIN|pink/black          |-  |pin switch or BCM           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|white               |   |blue plug, pin 49 @ PCM *2  |
|      SPEED SENSE|GREEN / WHITE         |   |blue plug, pin 32 @ PCM *2  |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black or blk/yel    |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |driver door module          |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |front passenger door module |
|  LR WINDOW UP/DN|blue - brown        |A  |LR window switch            |
|  RR WINDOW UP/DN|blue - brown        |A  |RR window switch            |
| SUN RF OPN/CLOSE|blue/red - blue     |A  |sun roof motor              |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ white         |-  |radio                       |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|BROWN / white (dimmer)|+  |radio                       |
|    POWER ANTENNA|gray                |+  |radio                       |
|       LF SPEAKER|tan - gray          |   |radio                       |
|       RF SPEAKER|lt. green - green   |   |radio                       |
|       LR SPEAKER|brown - yellow      |   |radio                       |
|       RR SPEAKER|blue - lt. blue     |   |radio                       |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use PLDATA.  *1 The liftgate glass ajar switch wire is purple. It is also located at the liftgate module in the liftgate.  *2 The PCM (Powertrain Control Module) is on the driver side of the motor.
orionmeades
Member - Posts: 37
Posted: April 24, 2003 at 4:43 PM / IP Logged
THANKS A LOT JEFF
            YOU SAVED ME LOTS OF WORK AND FUSES
orionmeades
Member - Posts: 37
Posted: April 24, 2003 at 4:44 PM / IP Logged
thanks a lot jeff
    you saved me a whole lot of time and fuses
orionmeades
Member - Posts: 37
Posted: April 24, 2003 at 4:56 PM / IP Logged
any good remote starter add on worth recommending...again i have a alpine 8063 alarm
Posted: April 24, 2003 at 5:23 PM / IP Logged
Try the DEI Valet 551T : http://www.directed.com/security/valet/val_rs.asp#552t
