accessory source, 1998 catera
limit
Member - Posts: 24
Posted: March 23, 2011 at 10:01 PM / IP Logged
So I have a 1998 Caddi Catera and just my luck there is no accessory wire from the factory deck, as it uses a data line as its accessory. I need to find another source for accessory, anyone know of possible sources in this car? or another work around.
Thanks in advance,
jbarb
Member - Posts: 24
Posted: March 23, 2011 at 10:49 PM / IP Logged
Can run a wire from radio to fuse panel, find a fuse that lights up test light on acc, possibly wiper fuse.   Use a fuse tap or one of the fuses with a wire lead off of it.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 26, 2011 at 1:09 AM / IP Logged
Thanks in advance,
I promise you my friend, there is an extra/blank/unused acces. location on your fuse panal......
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
