viper 5901 h1/7
wilhen319
Member - Posts: 14
Posted: April 04, 2011 at 9:10 PM / IP Logged
My trunk input(H1/7) on the Viper wants a ground signal when the alarm is armed. If the input is not grounded the keypad says the trunk is open an the alarm sounds. Anyone know whats going on here? I thought the Viper will go off when it see's a ground signal?
blanx218
Silver - Posts: 654
Posted: April 04, 2011 at 10:04 PM / IP Logged
Whats the year, make & model of the car? Is this a new system or something that is recently malfunctioning?
wilhen319
Member - Posts: 14
Posted: April 04, 2011 at 10:22 PM / IP Logged
its a 2006 lincoln ls sport an no it's not a new install
blanx218
Silver - Posts: 654
Posted: April 04, 2011 at 11:16 PM / IP Logged
Was it installed professionally? If it was I would take it back to where it was installed and have them fix it. The tunk triggers on an 06 LS require a relay to isolate it and prevent feedback. They can commonly send false triggers to the alarm if not wired correctly.
wilhen319
Member - Posts: 14
Posted: April 05, 2011 at 11:07 AM / IP Logged
thanks i would have took it back but i live in tx know i'm in the military so im no longer where it was installed but i found out that i just need to put a diode on the 12v wire coming from the light in my trunk which is making my alarm go off
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
