2011 kia rio wiring diagram
vmcfly
Posted: May 04, 2011 at 8:22 PM / IP Logged
i am looking for a wiring diagram for a 2011 kia rio lx, i am hooking up a pioneer dvd nav system and alarm with remote start  thank you
vmcfly
Posted: May 04, 2011 at 8:25 PM / IP Logged
also one of my main concern is the back up wire and speed sensor wire,  thank you
flobee4
Silver - Posts: 585
Posted: May 04, 2011 at 9:15 PM / IP Logged
reverse light - (+) WHITE/ black @ drivers side fuse box, center 14 pin brown plug - pin 10. There are 2 WHITE/ blacks coming out of the same Pin. They are common.
Parking Brake - (-)GREEN/ Orange same brown plug as above Pin 1.
Speed Sense - RED / Orange - OBDII connection Black 16 pin plug, pin 6 or radio, gry 8 pin plug, pin 1
As for the Remote starter - Link
That link doesn't show Negative Parking lights as an option, here is the info:
Pink/black or Red @ headlight switch, blue 20 pin plug, pin 10.
Also, If it has a factory alarm:
Arm - yellow/orange (test with driver door key cylinder)@ driver kick, green 42 pin plug, pin 35
Frank
vmcfly
Posted: May 05, 2011 at 5:54 AM / IP Logged
thank you frank
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
