toyota sienna 2004 unlock problem
tinchote
Member - Posts: 24
Posted: June 20, 2011 at 9:32 PM / IP Logged
Hi all, I'm having the following problem with my Sienna. A while ago, I started having trouble with the remote unlock in my 2004 Sienna.
Initially I thought it was an issue with the remote starter (so I started [url=https://www.the12volt.com/installbay/forum_posts.asp?tid=127238&KW=sienna+2004+lock]this thread[/url]).
But today I spent a while with a multimeter and I found that the issue seems to be unrelated to the remote starter.
Thing is that the unlock wire appears to be grounded all the time. It looks to me that there is a shorted wire somewhere, as this would explain both the fact that the unlock wire is grounded, and that the problem started happening once in a while until now that it basically happens all the time.
Now, I have no idea where/how to search for the shorted wire. If it is any help, the unlocking from the door switches works perfectly. It's only the unlocking coming from the remote control that doesn't work (I think that the wire that the starter uses is the one from the factory remote).
Mike M2
Platinum - Posts: 2,652
Posted: June 21, 2011 at 6:19 AM / IP Logged
If connected correctly, your remote starter uses the lock/unlock wires that come from the drivers key cylinder. Try turning the key in the door and listen. You should hear the power locks move the drivers first, then the others on a second turn.
Mike M2
Tech Manager
CS Dealer Services
Posted: June 21, 2011 at 6:50 AM / IP Logged
This is probably a lock processor control glitch. Place a 1N4004 diode in line from your R/S unlock wire band towards the R/S. Do the same for the lock wire although it's not affected right now.
This might cure the problem.
tinchote
Member - Posts: 24
Posted: June 21, 2011 at 9:43 AM / IP Logged
The key and the switches work perfectly. It's only the remote that doesn't open the doors. When I click the remote I hear the relay inside the R/S work, too.
tinchote
Member - Posts: 24
Posted: June 21, 2011 at 9:44 AM / IP Logged
Thanks, I will give it a try.
tinchote
Member - Posts: 24
Posted: June 23, 2011 at 4:37 PM / IP Logged
I still haven't tried the diodes, but I solved the problem by cutting the wire that goes into the wireless receiver (which is where the R/S is hooked).
Mike M2
Posted: June 23, 2011 at 6:50 PM / IP Logged
I see. Simply put, if the lock outputs don't work the unit is bad. Try disconnecting them right at the unit and check there to see if they work...
Mike M2
Tech Manager
CS Dealer Services
tinchote
Member - Posts: 24
Posted: June 24, 2011 at 2:19 PM / IP Logged
That was my idea. But I really couldn't figure out the cable mess behind the dash. It looks like it first goes from the receiver to the ECU and from there it crosses the whole dash again towards the pillar. I ended up cutting the cable precisely because I didn't have the time nor energy to keep removing things in the dash.
And I couldn't find a "door wiring" diagram for my van either.
Tuesday, January 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
