99 porsche carrera r/s
pitoaudiovisual
Copper - Posts: 388
Posted: July 01, 2011 at 8:32 AM / IP Logged
Im trying to do a remote starter on a 99 Porsche and the only issue i have is how to get to the ignition harness. I found all the wires like door lock, door triggers etc but i dont kno exactly how to remove the headlight switch or how to get to the ignition harness without bringing the whole dash down. Thanks in advance.
Confidence is the key to any project!!
Posted: July 01, 2011 at 1:19 PM / IP Logged
The ignition switch wiring comes down below dash then goes through a plug at the bulkhead to the front compartment. You should be able to grab enough loom there.
N.B. As per BMW, make the ACC ignition 2.
Siren position rear right of rear engine bay, pull out back seat trim, there's an engine bay grommet there. Factory alarm if present is under the right hand seat, that's a right PITA to remove and replace.
Posted: July 01, 2011 at 1:23 PM / IP Logged
Sorry, left hand front seat, I'm posting the installation guide in the Downloads/Manuals section, wait 5 mins.
Posted: July 01, 2011 at 1:27 PM / IP Logged
Done!
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
