2011 ford f 150 platinum edition
kalen427
Posted: July 04, 2011 at 9:44 PM / IP Logged
Does anyone please have the radio and factory amp schematic for a 2011 ford f150 platinum edition with Sony system and SYNC? I am trying to locate the factory amp and also need the wiring colors for the low level input and the high level output. Any help is very appreciated. Thank you.
bASSFREAK
Posted: September 18, 2011 at 5:04 AM / IP Logged
Yea here's the wiring colors for the 2011 F150
Left front
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are white - WHITE/ brown at the amplifier, gray 16 pin plug, pins 2 and 10. The tweeter wires are GREEN/ orange - gray/orange at the amplifier, gray 16 pin plug, pins 3 and 11.
Right front
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the amplifier, gray 16 pin plug, pins 6 and 14. The tweeter wires are PURPLE / orange - yellow/orange at the amplifier, gray 16 pin plug, pins 7 and 15.
Left rear
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier, gray 16 pin plug, pins 4 and 12.
Right rear
If equipped, the amplifier is under the center console. On vehicles with amplifier, the speaker wires are BROWN / white - BROWN / blue at the amplifier, gray 16 pin plug, pins 8 and 16.
Factory Amp Turn-on      PURPLE / red        radio, gray 8 pin plug, pin 4 or gray 24 pin plug, pin 7
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
