sub cutting out
lesterjustin29
Member - Posts: 13
Posted: August 07, 2011 at 8:52 PM / IP Logged
Ok i jus installed a wiring kit thats for up to 2000 watts... The sub is a sony xplod 12 an a sony xplod 600 watt amp all wired at 4ohms...Nothin big jus give it a lil bump.. Anyway i hooked it all up an works good til it hits low.. Tha amp dont cut out jus tha speaker... Everything is new besides a box that converts speaker wire to rca jacks and im stumped i cant figure it out please help
DYohn
Platinum - Posts: 10,741
Posted: August 07, 2011 at 9:42 PM / IP Logged
Check the Hot Topics forum and make sure you have set your gain correctly.
itsyuk
Silver - Posts: 505
Posted: August 08, 2011 at 4:09 AM / IP Logged
if you amp has a set of rca jacks coming back out, hook a set of headphones or something with ca inputs to them and see if  they go dead as well when it cuts out.
where is the wattage coming from that goes into the box you mentioned?
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
itsyuk
Silver - Posts: 505
Posted: August 08, 2011 at 4:11 AM / IP Logged
tell us all your model numbers.... even the converter box.
yuk
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
