2012 elantra
phil6710
Copper - Posts: 89
Posted: August 19, 2011 at 12:10 AM / IP Logged
I am looking for the trunk relese wire for this vehical. I am installing an Astra 4000 starter/alarm by Scytek. The wiering info I have found says to conect directly to the trunk relese motor. I am looking to make a connection under the dash.
Solartech Window Tinting and Electronics,contract installer
chev104275
Gold - Posts: 1,436
Posted: August 19, 2011 at 5:39 AM / IP Logged
I haven't worked on the car but is there a truck release switch ? You should be able to test the wires there and find what you need
Mike M2
Platinum - Posts: 2,652
Posted: August 19, 2011 at 6:18 AM / IP Logged
The 2012 is the same as the 2011. By "use trunk release motor" they mean use the motor wire, which is red(positive) at the dash fuse box, white 39 pin plug, pin 38.
Mike M2
Tech Manager
CS Dealer Services
Tuesday, January 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
