2006 f150 wiring information
marko79
Posted: August 30, 2011 at 2:33 AM / IP Logged
Hi, I bought a viper 5501 kit and try to fit it to my truck but in my country nobody is able to install it
Can someone be able to provide a 2006 F150 wiring color in order to install the kit
Please let me know
Regards
MARK from NEW CALEDONIA in the south Pacific
Platinum - Posts: 7,827
Posted: August 31, 2011 at 9:19 PM / IP Logged
Bulldog has the wire guide at  : http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
DEI has a wire guide at : http://www.readyremote.com/main.asp?make=Ford&model=F150
Remember that the wire guides are only guides.  Locate and verify all wires with a Digital Multi Meter.
You will probably need a transponder bypass (all U.S. F-150's do ).  Here is a link to one bypass option from Fortin :
https://ifar.ca/en/products/flash/key-override-all/
Here is a link to the Viper 5501 install guide :  https://www.the12volt.com/installbay/file.asp?ID=967
Good Luck!
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
