rubbing noise in sub
jgonzales82
Member - Posts: 12
Posted: November 12, 2011 at 1:26 AM / IP Logged
well i have a mtx 12' 8500 4ohm. so the sub sounds good with the volume half way but when i turn it up some the bass sounds good but when deep bass kicks in you can hear rubbing noise in the voice coil. is there anyway i can fix that?
jgonzales82
Member - Posts: 12
Posted: November 12, 2011 at 1:31 AM / IP Logged
also while the sub was off i pushed on the cone to see i can any rubbing and i heard nothing scratching at all
haemphyst
Platinum - Posts: 5,059
Posted: November 13, 2011 at 12:25 AM / IP Logged
It's blown or contains a manufacturer's defect. If you've never overpowered it (and they'll be able to tell...) call MTX or your local dealer, and have them RMA or replace it.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
