need rs 2009 mini cooper
wissman38
Posted: November 26, 2011 at 10:37 PM / IP Logged
need a remote start wiring diagram for a 2009 mini cooper clubman with push to start. I am using a DLPK and an KIBMW modules which i have ordered. putting in an avital 4113 Remote start. hoping to have fun with my first PTS, let me also know if the clubman is different than the regular cooper. thank you guys
reyhb
Member - Posts: 24
Posted: January 22, 2012 at 12:01 AM / IP Logged
     Ignition 1          RIBBON HARNESS          (-)          AT VEHICLE START/STOP BUTTON
     Starter 1          WHITE          (+)
AT CAR ACCESS SYSTEM MODULE UNDER DRIVER DASH ABOVE STEERING COLUMN          *Not for Remote Start
     Anti-Theft Type          BMW EWS® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Speed Sense          BROWN          (AC)          AT ABS CONTROL MODULE BETWEEN LEFT FRONT STRUT TOWER AND FIREWALL
     Parking Lights          USE INDIVIDUAL PARKING LIGHT WIRES AND DIODE ISOLATE EACH WIRE OR USE HAZARDS
     Brake Lights          BLUE/RED          (+)          AT SWITCH ABOVE BRAKE PDEAL ALSO AT FOOTWELL MODULE IN DRIVER KICKPANEL
     Reverse Lights          BLUE/GRAY          (+)          AT FOOTWELL MODULE IN DRIVER KICKPANEL
     Horn          BROWN / YELLOW          (-)
AT MODULE IN PASSENGER KICKPANEL ALSO RED / BLUE (+)
Posted: January 22, 2012 at 12:28 AM / IP Logged
From your point of view no, tach not mentioned above, should be black wire to OBD (data) socket.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
