07 pontiac g5 gt
vvwjetta2002
Posted: December 03, 2011 at 10:04 PM / IP Logged
Installed a compustar cm6200 in this 07 pontiac g5. It has a blade in the cm6200. the car is a manual. I can't seem to the reservation mode to take. I do exactly what they say in the manual. I have a 02 jetta with an older compustar in it so i know how to set it. The car shuts off its suppose to once the door closes. Then you try and start it and error 07 which is reservation mode not set. Tried playing with all the reservation mode options still nothing. Got any ideas
tedmond
Gold - Posts: 4,610
Posted: December 04, 2011 at 8:28 AM / IP Logged
is your door trigger hardwired or by the blade?
can you set reservation mode and get out of the car with the car still running, until you close the door?
Ted
Compustar Expert
vvwjetta2002
Posted: December 04, 2011 at 11:12 AM / IP Logged
The blade is taking care of the door triggers. And yes the car is running when you get and close the door and then it shuts off. i found this yesterday but i don't know if it i will help with the blade. it says to diode the door triggers and the rap.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
