95 regency
coolen
Copper - Posts: 121
Posted: December 05, 2011 at 7:04 AM / IP Logged
I had a gentlemen call me to inquire about a remote start for his olds. I told him that there was a way to get around the anti theft without an actual bypass module. He said he'd get back to me. When he called me back- i dunno who he called but he was told that since he had a resistor in the key, (on the shank)- that his anti theft was "unarmed" by that resistor pushing something apart within the tumbler. Is this true?
I've done quite a few remote starts on newer vehicles, but I have not come across the actual chip in the key shank yet, so I'm seeking some advice. I've read about finding the resistor value, and soldering in a new resistor inline. With that being said, how similar to the passlock is this system? In other words, with the OEM key close to the ignition, and if the car was started with a blank......would it start?
Thanks all!!
Posted: December 05, 2011 at 8:05 AM / IP Logged
No, that works with an RFI chip this is the older (and simpler) GM pass-key system, you simply use a resistor inline.
Platinum - Posts: 7,828
Posted: December 05, 2011 at 6:44 PM / IP Logged
Search on VATS for more info.  Just as Howard explained, in-line resistor to bypass.
tedmond
Gold - Posts: 4,610
Posted: December 05, 2011 at 8:33 PM / IP Logged
dont bypass it permanently if you can avoid it.
also, sure a resistor and relay costs 5 bucks, for an extra 10 bucks using a self learning bypass prevents failed starts in cold weather etc.
ive used many resistor/relay setups, and its a hit and miss. some never have probs, some come back .
Ted
Compustar Expert
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
