door triggers
beanie92
Posted: December 12, 2011 at 1:10 AM / IP Logged
how do you wire a warlock alarm system to the door triggers in a 1996 holden barina plz help?????
beanie
Posted: December 12, 2011 at 7:10 AM / IP Logged
The best answer would be to go to the wire on the dome light switch one of three which goes to ground when the door opens.
Since probably no one here has heard of a Warlock alarm and few here have any idea what a Holden is I can't give you specific colours.
I assume you mean door triggers rather than lock/unlock.
Posted: December 12, 2011 at 7:19 AM / IP Logged
I did the research you should have done which was to Google/Wiki it and find it's a Vauxhall Corsa.
Door trigger is grey - going up left hand "A" pillar, remove glove box and lock wire is BROWN / red - whilst unlock is BROWN / white - in loom to front passenger door, you might also find the grey there coming from the left hand door switch.
12v+ Red,
Ignition Black,
Starter RED / black or BLACK/ red (can't remember which way round).
Earths (grounds, 0V) are plain brown, indicators are BLACK/ green (right)) and BLACK/ white (left).
beanie92
Posted: December 12, 2011 at 2:28 PM / IP Logged
how u suposed to wire it up to the door triggers
beanie
Posted: December 12, 2011 at 4:00 PM / IP Logged
To the wire on your alarm that says "door trigger or door switch".
From your questions you are evidently never going to install this with your evident lack of knowledge or capabilities.
I'm not here to hold your hand so why don't you just print a list of the alarm wires and what Warlock says are their functions and we'll take it from there.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
