07 nissan murano neutral safety
armbruster
Member - Posts: 32
Posted: December 15, 2011 at 3:43 PM / IP Logged
I am getting ready to do my first Murano and noticed that DEI has a warning about installing a neutral saftety relay is a must. Can someone clarify for me exactly what extra is required over the normal install? I have done hundreds of installs and have never seen such emphasis on this subject.
2007 Nissan Murano (not a PTS)
DBALL for the bypass & integration of an Avital 5303 (Alarm/RS)
Thanks in advance for the help all.
Posted: December 15, 2011 at 3:48 PM / IP Logged
Auto or manual
tedmond
Gold - Posts: 4,610
Posted: December 15, 2011 at 3:56 PM / IP Logged
murano only came in auto.
it wont start in gear so just ground the nss wire.
Ted
Compustar Expert
Posted: December 15, 2011 at 5:12 PM / IP Logged
NSS is only relevant to manuals, some have a second (apart from VSS) hall effect switch built into the gearbox, it goes to ground when the vehicle is in neutral. Connect your NSS to that and you can set it up as an auto, i.e. R/S at any time.
metz35
Copper - Posts: 458
Posted: December 15, 2011 at 6:34 PM / IP Logged
i know compustar/idatalink, make you do a neutral safty on all nissans, that are PTS and Intellikey...but regular key they do not.
armbruster
Member - Posts: 32
Posted: December 26, 2011 at 4:44 PM / IP Logged
It is the "Smart Key" version of the Murano (not the PTS) - everything I pull up on DEI (xpresskit.com) warns me of the necessity of a NSS relay being installed or the vehicle will jump, even in gear.
Can someone walk me through what exactly I should be doing, if necessary?
jstruckman
Copper - Posts: 465
Posted: December 26, 2011 at 6:44 PM / IP Logged
DEI and idatalink both say to use a relay in at the underhood fusebox. just follow the instructions that DEI shows you about wiring in the relay at the underhood fusebox. This will keep it from starting if in gear if i remember correctly.
offroadzj
Gold - Posts: 2,043
Posted: December 26, 2011 at 7:19 PM / IP Logged
Not sure if you've already bought the components, but the Fortin Evo-ALL bypass has a simplified installation that is much easier than the DB-All. It will require a hardware version 3.0 or higher and firmware version 4.0 or higher bypass but it makes life easy on newer Nissans. From what I can see in the install guide, it does not require the extra relay either.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
