electric fan, wiring check, on/off/on, therm
Posted: January 24, 2012 at 12:08 AM / IP Logged
You won't need a "heavy duty" switch you're only switching relay coils max draw, 3 amps.
What's the on rush draw (switching on current draw) of each fan, add about 5 amps to each, that becomes your fuse and relay rating, either one fuse X twice that rating as per the diagram above or two feed lines and fuses, one for each relay, IMO safer.
P.S. From your questions here, I would suggest you follow that diagram slavishly.
superjatt
Member - Posts: 10
Posted: January 25, 2012 at 3:04 PM / IP Logged
. I had the fans wired up before with relays but I did not have an over ride switch to them.
Thank you so much for you input!
Sc300 - 2jzgte
oldspark
Gold - Posts: 4,913
Posted: January 25, 2012 at 8:54 PM / IP Logged
The override switch should switch the relay(s), not the fan power. It just needs a few diodes (IN4004 etc) and a low-power switch.
Page of 3
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
