viper 5704, 2004 f150
tbone40
Posted: January 29, 2012 at 12:55 PM / IP Logged
Installing 5704 Viper in my 2004 F150.  Unable to get an installation manual from DEI as I am not a dealer.
I did not want anybody hacking into my wiring so i want to do it myself.  I have referenced the
5901 and the 5701 manuals to identify as much wiring as possible.  I have attached a chart of each
connection that i have made on the vehicle, and i am still having trouble with some of the 24 pin connecter wires. Does anybody have any knowledge of this installation and could advise me on the connections i have
chosen for each tie in point.
Remote Start Heavy Gauge Connector (10Pin)
# Comments         Viper   F150
H3/1 (+) Inginition 1 INPUT/OUTPUT      Pink Ignition Harness (Lt GREEN/ Purple)
H3/2 Fused 30amp Ingnition 2 / Flex Relay input 87    RED / White 12 volt Constant
H3/3 (+) Accessory Output Orange        Ignition Harness (BLACK/ Lt green)
H3/4 (+) Starter Output (Car side of starter kill) Violet Cut RED / Lt Blue. Violet to Starter
H3/5 (+) Starter Input (Key side of starter kill)     Green Cut RED / Lt Blue.  Green to switch
H3/6 (+) Fused 30amp Ignition 1 Input (12V battery)     Red 12 volt Constant
H3/7 (+) Ingnition 2/ Flex Relay Output     Pink/White    Not Used
H3/8 (+) Flex Relay Input 87A key side     Pink/Black    Not Used
H3/9 (+) Fused 30amp Accesory/Starter Input    RED / Black    Drk. Blue/Lt. Green
H3/10 NO CONNECTION NONE NONE
Main Harness Connector (6 Pin)
H1/1 12 DC Constant Input   Red Battery
H1/2 Chasis Ground Black           Ground Connection
H1/3 Siren   Brown          Red wire from Siren
H1/4 Parking Light Issolation Wire WHITE/ Brown         Cut BR - WHITE/ Brown to switch
H1/5 Parking Light Output   White          Cut BR - White to vehilce
H1/6 500Ma ground when output   Orange        ???? Not Used
Door Lock (3 Pin)
1 (-) 500mA Unlock Output Blue   Pink/Lt Green
2 Not Used   Empty          Not Used
3 (-) 500mA Lock Output      Green          Pink / YELLOW
Auxilary/Shutdown/Trigger Harness (24 Pin)
H2/1 (-) 200mA Ignition/Flex Control Output           Pink/White       ????
H2/2 (-) Neutral Saftey Input BLACK/ White       Ground
H2/3 (-) 200mA 2nd Status Rear Defogger Output Blue/White       Not Used
H2/4 (-) 200mA OEM Alarm Disable Ouput GREEN/ Black     Not Used
H2/5 (-) 200mA Trunk Release      RED / White        Not Used
H2/6 (-) Door Trigger Input (N/C or N/O)     Green ??? BLACK / YELLOW
H2/7 (-) 200mA Dome Light Supervision Output    BLACK / YELLOW   BLACK/ Lt Blue BCM
H2/8 (-) 200mA Horn Honk Output BROWN / Black    Dark Blue
H2/9 (-) 200mA Status Output          Dark Blue         BLACK/ Pink
H2/10 (-) 200mA Ignition 1 Output   Pink       ????
H2/11 (-) 200mA Aux 3 Output          WHITE/ Black      Not Used
H2/12 (+) Door Trigger Input   Violet     ????
H2/13 (-) 200mA Aux 1 Output           WHITE/ Violet      Not Used
H2/14 (-) 200mA Aux 2 Output Violet/Black      Not Used
H2/15 (-) 200mA Aux 4 Output          ORANGE / Black     Not Used
H2/16 (+) Brake Shutdown Input       Brown     Lt Green
H2/17 (-) Hood Pin Output (N/C or N/O)        Grey       Hood Switch into Truck
H2/18 (-) 200mA Starter Output         Violet / YELLOW      ?????
H2/19 (-) Trunk Pin/Instant Trigger Input (N/C or N/O)   Blue    ?????  Not Used
H2/20 (-) Diesel Wait to Start Input    Grey/Black        Not Used
H2/21 (-) Remote Start/ Turbo Timer Activation Input WHITE/ Blue        ???? Not Used
H2/22 (-) 200mA Accesory Output     Orange    Not Used
H2/23 Tachometer Input         Violet/White        Not Used Virtual
H2/24 (-) 200mA OEM Alarm Output    GREEN / WHITE        Not Used
T-Bone 40
smokeman1
Platinum - Posts: 1,589
Posted: January 29, 2012 at 5:25 PM / IP Logged
There is a Viper 5904 in the download section of this site that might be of help to you.
Platinum - Posts: 7,828
Posted: January 29, 2012 at 6:15 PM / IP Logged
Corrected H3 connections for the 2004 F150
H3/1 (+) Inginition 1 IN/OUT               Pink      Dark Blue/Light Green
H3/2 (+) Fused 30amp Ingnition 2       RED / White       Not Used
H3/3 (+) Accessory Output   Orange    BLACK/ Lt green
H3/4 (+) Starter Output (Car side)     Violet   Cut RED / Lt Blue. Violet to Starter
H3/5 (+) Starter Input (Key side)        Green   Cut RED / Lt Blue.  Green to switch
H3/6 (+) Fused 30amp Ignition 1 Input        Red      12 volt Constant  (Lt GREEN/ Purple)
H3/9 (+) Fused 30amp Acc/Starter Input      RED / Black      12 volt Constant  (Lt GREEN/ Purple)
I believe there are multiple +12V constant wires at the ignition switch harness.  ( Might not all be Light GREEN/ Purple.)
Posted: January 29, 2012 at 6:24 PM / IP Logged
Main Harness Connector (6 Pin)  corrections :
H1 connector        Viper            F150
H1/1 12 DC Constant Input        Red            Light GREEN/ Purple @ Ignition Harness
H1/4 Parking Light Issolation Wire       WHITE/ Brown          N.U.
H1/5 Parking Light Output          White           Brown(+) @ Headlight Switch   ***Viper jumper/fuse set to (+)
H1/6 500Ma ground when output          Orange       N.U.
Posted: January 29, 2012 at 6:47 PM / IP Logged
H2 connector         Viper                  F150
H2/1 (-) 200mA Ignition/Flex Con              Pink/White           N.U.
H2/2 (-) Neutral Saftey Input        BLACK/ White     Ground if Auto Trans
H2/3 (-) 200mA 2nd Status Rear Defog Out      Blue/White       Not Used
H2/6 (-) Door Trigger Input (N/C or N/O)             Green   BLACK / YELLOW and BLACK/ Pink w/diode isolation
H2/7 (-) 200mA Dome Light Supervision Out    BLACK / YELLOW    BLACK/ Lt Blue BCM ( not necessary if lights come on with unlock )
H2/8 (-) 200mA Horn Honk Output         BROWN / Black      Dark Blue @ 6 Pin plug right of steering column
H2/9 (-) 200mA Status Output    Dark Blue       To GWR on bypass module
H2/10 (-) 200mA Ignition 1 Output           Pink    N.U.
H2/12 (+) Door Trigger Input       Violet               N.U.
H2/16 (+) Brake Shutdown Input Brown     Lt Green @ Brake Switch
H2/18 (-) 200mA Starter Output             Violet / YELLOW   N.U.
H2/19 (-) Trunk Pin/Instant Trigger In      Blue    Not Used
H2/21 (-) Remote Start/ Turbo Timer    WHITE/ Blue         Not Used
H2/23 (AC) Tachometer Input  Violet/White       any wire not Red or RED / Lt Green @ any F.I.
A couple of notes:
What are you using as a bypass module?  Your truck should have the Ford PATS3 immobilizer system.
Additionally you will need two working, non-clone, ignition keys to program the bypass module.
Domelight Supervision may not be necessary if the interior lights come on with an unlock.
For best results and reliable remote starts, run in Tach Mode and connect to a F.I.   Virtual
Tach doesn't work that well in cold climates.
tbone40
Posted: January 30, 2012 at 7:04 AM / IP Logged
I can't thank everyone enough for all the information. It is greatly appreciatted.
I do have to ignition keys. What bypass module do you recommend I purchase for this system?
T-Bone 40
Posted: January 30, 2012 at 7:30 AM / IP Logged
There are several good "Data type" bypass options for your truck.
DEI makes the PKALL
Fortin makes the Key-Override-All
iDatalink makes the ADS TBSL KO
All are very good modules and cost starts at $30 or so.
My favorite is the DEI 1100F.  It has been discontinued but remains available at various
"online" sellers for about $15.  It is actually made by iDatalink and similar to the
ADS TBSL KO ( but only capable of doing Fords ).  Very reliable and easy to program but
must be connected in the W2W mode ( only 3 wires to R/S ).
smokeman1
Posted: January 30, 2012 at 11:59 AM / IP Logged
I have used the Fortin and the DEI 1100f on Ford vehicles. Never had an issue with either of them. Simple to use and connect.
mccleader26
Posted: January 31, 2012 at 6:38 PM / IP Logged
Is the wiring the same for a 2007 supercrew? I was hoping to do a diy but this seems outta my league. And I cant find any installer close enough that doesnt charge an arm and a leg or that has a reputable image either. I have been told not to go to best buy and some other places as well. Any help would be greatly appreciated. I have the viper 5901 that was purchased online for christmas. I would like to add the 530t module for my front and rear windows and I need a bypass as well I think. I have both original keys from the dealership. Thanks again!
offroadzj
Gold - Posts: 2,043
Posted: January 31, 2012 at 6:42 PM / IP Logged
If you aren't comfortable doing it, then do yourself a favor and don't. It may seem like an arm and a leg for installation, but it will be both arms and both legs if you damage your ECU or something else. There is a reason good installers charge a premium... you get what you pay for. if you decide to continue anyways, make your own thread. Hijacking another thread can get you banned from the site.
just my .02
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
