2008 chrysler sebring convertible
jseibold
Copper - Posts: 98
Posted: February 06, 2012 at 9:07 PM / IP Logged
Can anyone provide a sheet for a 2008 Chrysler Sebring convertible?  Checked on this site and didn't see one.  I'll be doing an alarm/remote start using an Audiovox/Prestige aps997 and a db-all for the bypass.  I have access to A-vox and Bulldog for the sheets, but there is another site that I actually prefer and my login no longer works.
ropuma
Copper - Posts: 102
Posted: February 07, 2012 at 9:47 AM / IP Logged
Try alertautomotive.com
shortcircuit161
Silver - Posts: 556
Posted: February 07, 2012 at 12:43 PM / IP Logged
You will want to use a bypass module for this vehicle. Locks and everything else is controlled via the CAN bus network on these vehicles.
Check idatalink.com or Xpresskit.com for Combo modules that do ignition, locks, trunk and more.
12volts      red      +      battery or TIPM
Notes: The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver side.
Starter      yellow/purple (for starter kill only)      +      driver fender, 20 pin plug, pin 12 (I-4); 14 pin plug, pin 6 (V6)
Second Starter      PURPLE / brown      - 180 ohms      ignition switch, black 5 pin plug, pin 2
Notes: If interface module is not available, see Tech Doc 1084 for wiring information.
Ignition      pink      +      ignition switch, black 5 pin plug, pin 3
Second Ignition      N/A
Third Ignition      N/A
Accessory      same as second starter      - 610 ohms
Second Accessory      N/A
Keysense      same as second starter      -8.5K ohms
Power Lock      lt. GREEN/ purple      - 330 ohms      driver kick or instrument cluster, brown 20 pin plug, pin 18
Power Unlock      same as power lock      - 100 ohms
Lock Motor      tan/dk. blue      5 wire      driver kick or instrument cluster, black 10 pin plug, pin 9
Unlock Motor      tan/dk. green      5 wire      driver kick or instrument cluster, black 10 pin plug, pin 5
Parking Lights+      WHITE/ purple      +      driver kick, harness to rear
Parking Lights-      (LIN BUS)
Hazards      (LIN BUS)
Turn Signal(L)      WHITE/ lt. green (F), WHITE/ dk. green (R)      +      turn signal light (F); driver kick, harness to rear (R)
Turn Signal(R)      WHITE/ tan (F), WHITE/ yellow (R)      +      turn signal light (F); passenger kick, harness to rear (R)
Reverse Light      WHITE/ lt. green      +      driver kick, harness to rear
Door Trigger      purple      -      dr kick or instr cluster, brown 20 pin plug, pin 3
Dome Supervision      yellow/white      +      driver kick or instrument cluster, brown 20 pin plug, pin 4
Trunk/Hatch Pin      PURPLE / orange      -      driver kick or instrument cluster, brown 20 pin plug, pin 13
Hood Pin      PURPLE / lt. blue      -      hood pin switch under hood
Trunk/Hatch Release      lt. GREEN / WHITE      -      release switch or instrument cluster, black 20 pin plug, pin 13
Power Sliding Door      N/A
Factory Alarm Arm      arms on lock with door open
Factory Alarm Disarm      factory remote only
Disarm No Unlock      Sentry Key, ignition, and keysense
Tachometer      NOT BROWN / yellow      ac      any fuel injector
Wait to start      N/A
Brake Wire      dk. GREEN / WHITE      +      brake pedal switch or instrument cluster, brown 20 pin plug, pin 8
Parking Brake      dk. GREEN / WHITE      -      parking brake switch or instrument cluster, brown 20 pin plug, pin 7
Horn Trigger      dk. GREEN/ purple      -      horn switch or instrument cluster, black 20 pin plug, pin 10
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
jseibold
Copper - Posts: 98
Posted: February 08, 2012 at 1:43 PM / IP Logged
Thank you Shortcircuit.  And yes I am using a DB-ALL for my Bypass.
