car missing 12 volt switched/ignition
m1ndz21
Member - Posts: 14
Posted: February 20, 2012 at 5:56 PM / IP Logged
I was going thru my wiring trying to clean up the unused stock speaker wires and I noticed that the stock ignition wire (12 volt switched) is missing and a wire was ran from a fuse instead, how can i fix this or add a wire the correct way? My car is a 2000 Monte Carlo if that helps
co_ne_dub
Copper - Posts: 80
Posted: February 20, 2012 at 9:25 PM / IP Logged
It's there. It is a data controlled wire which is why it wont work for an aftermarket deck. That is the reason for the wire from the fuseblock. Your chimes probably dont work either, right?
m1ndz21
Member - Posts: 14
Posted: February 21, 2012 at 3:01 AM / IP Logged
Yea the chimes don't work, so what's the best way to use an aftermarket deck in my car, would running a 12 volt switch to a relay work?
co_ne_dub
Copper - Posts: 80
Posted: February 21, 2012 at 6:16 AM / IP Logged
Both Metra and Scosche make the interface modules that would eliminate you having to run a switched wire from the fuse box.
Metra GMRC-01 would let you retain the chimes and give you a switched wire at the harness unless you have a BOSE system in which case you would use a GMOS-04.
soundnsecurity
Gold - Posts: 2,720
Posted: February 21, 2012 at 9:16 AM / IP Logged
assuming the plug hasnt been cut off yet.
m1ndz21
Member - Posts: 14
Posted: February 22, 2012 at 9:13 PM / IP Logged
the wires have been cut from the original connector, its the way i recieved the car, so....... running a switched 12 volt is the route to go?
co_ne_dub
Copper - Posts: 80
Posted: February 22, 2012 at 10:05 PM / IP Logged
It will work, absolutely.
