12v led strip lights dual power supply?
jamier3
Posted: March 05, 2012 at 8:48 AM / IP Logged
I have some led strips that I'm going to be putting in my headlights along with some halos. I want to be able to run them from the ignition and headlights instead of having a manual switch to change the lights. That part is easy...
The part I'm having a problem trying to figure out is I would like to have these strips be DIM (reduced voltage) when I have the car on and then full 12v when the headlights are on. Is this possible?
oldspark
Gold - Posts: 4,913
Posted: March 05, 2012 at 4:52 PM / IP Logged
Yes, except that dimming for LEDs is reduced current. It can still be done with a resistor, but it's a subtle yet important point. (Whilst current reduces in normal bulbs with reduced voltage (and brightness is essentially proportional to the current), LEDs do not dim proportionally to voltage. Put LEDs on traditional voltage dimmers (variable resistor) and they well dim slightly and then extinguish whilst bulbs are dimming "linearly".
Paraphrased or demonstrable - measure the voltage across a LED when bright and when dimmed - the voltage will not vary much.
Now the question is how? But first clarify the combinations eg:
IGN on - LEDs bright.
Lights on - LEDs dim.
IGN & Lights - LEDs dim.
Is that correct, and have I missed something?
And I assume +12V switching on IGN (yes of course) and the lights (they generally are).
This will be for a fully under-the-bonnet/hood installation with no cabin switching.
jamier3
Posted: March 07, 2012 at 7:58 AM / IP Logged
Sorry I missed your post...
I would like to have it like the following.
IGN on - LEDs Dim.
Lights on - LEDs Bright.
IGN & Lights - LEDs Bright.
And yes it would be fully under the hood with no switching. I might do a 'master' switch on the dash just so I can turn them all off if needed but I don't want to have to have 2 - 3 switches for different lights.
oldspark
Gold - Posts: 4,913
Posted: March 07, 2012 at 11:07 AM / IP Logged
I should first ask what the total current of the LEDs is, and after getting an answer, describe and ask which method you prefer (resistor or dimmer), and thereafter describe the gritty detail following....
But you being a Newbie, I may as well hammer you! 12v led strip lights dual power supply? - Last Post -- posted image. 12v led strip lights dual power supply? - Last Post -- posted image.
Actually it's me... It'll be sun-up in a few hours, and I started this (below) without much pre-thought and it got out of hand. (Again!) [Sorry, you are probably too new to know my, er, behavior.]
But I'll keep the full onslaught in case you can follow it and in case it provides some ideas...
Arguable the simplest solution is an SPDT relay (5 pin) with pin 30 to the LEDs, IGN +12V to 87a, and 87 from battery +12V via a resistor of R-Ohms & probably high Wattage rating (see below).
With #85 to GND, the beam's or taillight's (whichever you prefer) switched +12V energises the relay's #86 thus the relay's #30 contact changes over from #87a to #87.
The resistor R is added in series to the LEDs when the relay is on (ie, +12V via R to 87 and out thru 30 to the LEDs).
It's value can be found by experimentation to give the dimness you require...
.. or one can estimate its value and power rating if the number of series LEDs is known (probably 3 - white LEDs are about 3.3V each, hence ~10V if 3 in series) as well as the total LED current, else the number of parallel strings and current per string or LED - probably 20mA each LED/string. (A 10A ammeter or DMM is probably easiest, and best.)
Alternatively, to f.ex halve the current and hence about half the brightness, find what value resistors are used, how many are used, and the get a resistor of value R Ohms where R = r/n and r = each (string's) resistor value (Ohms), and n is the number of strings or resistors.
The resistor's power/Wattage rating is based on IxIxR where I is the total LED current at full/normal brightness. For half current (R = r/n Ohms), the rating should exceed 1/4 of IIR (ie, it's I/2 x I/2 x R).
Confused? A diagram may explain the circuit better, but the total LED current needs to be known for an estimate of the resistor.
There are numerous ways of making that Resistance estimate, and if unknown it can be assumed there are 3 LEDs in series (plus a resistor) in each string, though some may use 4 (white) LEDs and maybe no resistor.
ALTERNATIVELY - and more elegant and arguably simpler - use a PWM dimmer as found in most modern vehicles for dash etc dimming and switch that in. (Or build your own if so inclined... a simple 555 circuit driving a MOSFET.)
[ FYI - Dash dimmers are usually designed for up to 10A which is lots of 20mA LED strings.
EG, up to 10A/20mA = 500 20mA strings, each probably with 3 LEDs, hence 500 x 3 = 1500 dimable LEDs! ]
With a PWM dimmer you set the appropriate dimness, and maybe tape over its dial to prevent drift.
Note that PWM dimmers don't get hot like resistors do - very little power is wasted.
The only catch is that most PWM dimmers are grounding - ie, +12V goes to the LEDs/lights which then ground via the dimmer.
But that's no major problem; the -ve end of the LEDs goes to the relay's 30' 87a to GND; and 87 via the dimmer to GND.
The relay is still activated by the light circuit (ie, switched +12V to 86) but the +12V supply to the LED +ve end is either through diodes, else another (SPDT) relay - especially if the LED current is high (above say 3A or 5A, though 10A diodes are available).
But I'll save that - and the diagram(s) - until you respond to the above with whatever you can; whether it's confusion or the Amperage and maybe resistor & string/LED info etc.
BTW - PWM dash dimmers down here are usually ~$10 from auto wreckers/recyclers, though I hear that some have apparently walked out from "self-serve" wreckers. 12v led strip lights dual power supply? - Last Post -- posted image.
jamier3
Posted: March 07, 2012 at 3:10 PM / IP Logged
Gritty detail you say? I might have to go back to school for most of that. 12v led strip lights dual power supply? - Last Post -- posted image.
There were no specs with the LEDs so I will look tonight to see if there are any markings on it to see if it shows anything. All I know is that it is 12V.
I do like the idea of PWM dash dimmer but have not found one that has 'click' settings so you know what setting you are at... (dim vs. bright)
Thanks for the detailed reply... more info later.
oldspark
Gold - Posts: 4,913
Posted: March 07, 2012 at 6:58 PM / IP Logged
Yeah, though its brevity (LOL) is typical for me, I am sorry...
Even though I know long is counterproductive (less IS more!), I still seem to write to teach and provoke (...ideas!). It works well in person, but often fails miserably in text - unless it's reviewed after intervals.
Note that the PWM overcomes any need for LED-string investigation - assuming it insn't around 10A or higher which it won't(?) be - try a 5A fuse and run for say 30 minutes to confirm - nles a smaller fuse is already fitted.
But the advantage of the typical dash dimmer is that you can set the desired brightness easily, and change it later. But you could always substitute 2 resistors in place of the pot, though I'd prefer a dab of glue.
The same for the following ancient 555 circuit...
Whilst you decide if you want the (clever, superb, power efficient, nice tech bling) dimmer solution, I'll consider the wiring & diagram for it.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
