crimestopper rs7 and xpresskit ch all
poppershea
Member - Posts: 7
Posted: March 31, 2012 at 9:25 AM / IP Logged
I am installing a crimestopper rs7 and expresskit ch-all in a 2010 grand caravan. I have the ch-all installed and programed but the d2d wire does not match up between the ch-all and the rs7 So I am going to do a w2w install. I would like it if someone could look at the install manuals of the 2 and give me a run down of what wire goes to what wire and what wires I need to connect directly to the vehicle. Not sure if it is okok to post links but i will since they are freely downloadable and ditributed.
http://www.xpresskit.com/DocumentDownload.aspx?documentid=7173&productid=448&firmwareid=1637
http://www.crimestopper.com/Templates/2009_manuals/RemoteStart/rs-1-3-4_ins.pdf
Thank you
poppershea
Member - Posts: 7
Posted: March 31, 2012 at 1:28 PM / IP Logged
poppershea
Member - Posts: 7
Posted: April 02, 2012 at 2:25 PM / IP Logged
Sorry to sound desperate, This will be my 3rd install but first wire to wire. I'm pretty sure I have it figured out but don't wanna get it wrong. If someone could please look it over that would be great. Thanks again.
Platinum - Posts: 7,828
Posted: April 02, 2012 at 6:06 PM / IP Logged
RS7
12 Pin Low Current Plug
Yellow/White  Horn(-)   Caravan Dark GREEN/ Purple @ horn switch
Orange ARM(-) Not Used
Pink Wait to Start(-)       Not Used
Gray Hood Pin(-)          To hood pin switch    (CH-ALL Pink/Black - if Factory equipped)
Purple Brake(+) CH-ALL Orange
Green Satrt Act(-)          Not Used
RED / White Tach(AC)    CH-ALL Pink
Black Chassis Ground Caravan chassis ground
Brown Trunk(-) CH-ALL Yellow/Black    (unlocks with doors)
Yellow/Black IGN1(-)    CH-ALL Blue
White Parking Lights                 Caravan WHITE/ Purple in DKP   ***Set for (+)***
ORANGE / Black Disarm(-) Not Used
3 Pin Door Lock Plug
Blue Unlock(-) CH-ALL PURPLE / White
Red +12V         Not Used
Green Lock(-) CH-ALL Purple
6 Pin High Current
Red x 2 Caravan +12V constant Battery
Pink   Ign        CH-ALL Yellow
Brown Starter CH-ALL Light Blue/Black
Gray Accessory           Not Used
Pink/White Flex           Not Used
flobee4
Silver - Posts: 585
Posted: April 02, 2012 at 6:38 PM / IP Logged
To do w2w you just match up the wires listed on the CH-ALL to like wires on the crimestopper. So Trunk wire of the crimestopper to the trunk wire input wire of the CH-ALL
CHALL  Function     Crimestopper
Yellow/Black     Trunk        Brown
PURPLE / White     Unlock        Blue
Pink/Black     Hood Status     Gray
Lt Blue/Black    Start        Brown Thick Start wire
Yellow  Ignition     Pink Thick Ignition Wire
Purple Lock        Green
Orange Brake        Purple
Blue        (-)while Running   Yellow/Black
Pinktach        RED / white
On the crimestopper you only need to connect to the car: Ground, Both RED power wires and Parking lights.
Ground - to metal grounding point
Both 12 Volt wires - Usually there is a yellow/red Power wire in the kick area of Dodges. I haven't done a 2010 yet, but it used to be in a black plug with a white trim. It was next to the ebrake mechanism. TEST!
Parking lights - WHITE/ Purple (+) in the drivers kick panel, the harness running to the rear of the car. If the crimestopper has a jumper, make sure the jumper is set to positive. If your crimestopper has a RED / black wire with a 10amp fuse in it, it will need to be connected to the same place as the 2 red power wires.
Happy wiring,
Frank
poppershea
Member - Posts: 7
Posted: April 02, 2012 at 8:25 PM / IP Logged
Awesome! Thanks for all the info guys. I will post back if I have any more questions and to let you guys know how it goes.
poppershea
Member - Posts: 7
Posted: April 03, 2012 at 8:01 PM / IP Logged
Soldered all the wires together today and installed the remote start in the van. Every thing went great! Not a single setback. Thank you very much Kreg, Frank, and 12volt.
Posted: April 04, 2012 at 12:50 AM / IP Logged
Good job!   crimestopper rs7 and xpresskit ch all - Last Post -- posted image.   Thanks for the update.  ( Soldering really is fun and W2W always works.)
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
