2011 nissan rogue base model regular key
triniforever
Copper - Posts: 323
Posted: April 09, 2012 at 9:42 PM / IP Logged
Hey all, i recently did an  Avital 5303 alarm and remote start on this vehicle and used a DBALL bypass took the can high and can low wires from the diagnostic plug under the driver's dash,however no matter what i did the DBALL did not program .What happened was the module would program with the LED going green and then flash and then turning off then it would turn green and turn off again,i tried for hours but no go ,even took the can high and can low from the BCM behind the glove box and the module did the same thing. Any reason its doing this?        thanks for any help..................................triniforever
triniforever
Twelvoltz
Platinum - Posts: 2,384
Posted: April 10, 2012 at 7:20 PM / IP Logged
Did you use D2D or W2W? The Avital stuff doesn't play well with D2D.
triniforever
Copper - Posts: 323
Posted: April 11, 2012 at 9:04 AM / IP Logged
i did W2W
triniforever
duffmanaudio
Member - Posts: 11
Posted: April 16, 2012 at 3:31 PM / IP Logged
Did you try with the doors closed? I work at a nissan dealer & use the automate am6.2 + dball. Though I have never had any problems programmimg.
we hook up the GREEN / WHITE door pin output from the dball to the hood pin input of the r.start. This allows a better takeover & you don't need to interupt the security light wire. We tage the can wires at the diag port.
Other than that its a very simple install
triniforever
Copper - Posts: 323
Posted: April 17, 2012 at 3:19 PM / IP Logged
I tried a new DBALL and it programmed right up so i guess the first module was bad and i didnt need to interupt the security light cuz when the key tookover the light went out and didnt flash.........and hoodpin wire trick sounds interesting i will try it next time ........thanks .....................triniforever
triniforever
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
