Color code 2002 Expedition
prplpasn
Member - Posts: 9
Posted: June 15, 2002 at 12:34 AM / IP Logged
I need the wire colors for a  2002 ford expedition.  I am hooking up alarm with all the wistles.  All the wire colors you can give me will be mcuh appreated.  Thanks.
Platinum - Posts: 12,488
Posted: June 15, 2002 at 8:25 AM / IP Logged
Ford
Expedition
1997-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED / L BLUE
IGNITION SWITCH HARNESS **
Ignition  #1:
D BLUE/GREEN
Ignition #2:
RED / BLACK
Ignition  #3:
GRAY / YELLOW
Accessory:
BLACK/ L GREEN
Brake  Light:
L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE/ PINK
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
RED / YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
D GREEN/ PURPLE (-)
DRIVER KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Powertrain Control Module (PCM) Located On Passenger Side Of Engine Compartment On Passenger Wheelwell. ** This Vehicle May Be Equipped With Ford's PATS Anti-Theft System.
Ford
Expedition
1997-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
YELLOW (2), ORG/YEL &
L GREEN/ PURPLE (2) IGN. SW. HARNESS
Starter  Kill:
RED / L BLUE
Ignition  +12 Volts:
D BLUE/GREEN
Dome  Lights/Superv:
BLACK/ L BLUE (+)
PASSENGER KICK PANEL
OEM Horn:
D BLUE (-)
STEERING COLUMN HARNESS
Power  Lock:
PINK / YELLOW
DRIVER'S KICK PANEL ***
Power  Unlock:
PINK/L GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ L BLUE (+)
Notes:
*** Without OEM Keyless Entry  Reverse Polarity Door Lock ,With OEM Keyless Positive Pulse Door Lock
