new fusebox but on amp.
ls2cam
Member - Posts: 8
Posted: September 03, 2012 at 10:23 PM / IP Logged
I fabbed up new fuse box for my camaro car Ls2 carbed without controlled programs (PCM)
I forget, how figure to how much ampere fuse each on these 6 slots
Slots:  Slots:
1) 12 ga. (12V hot) / 12 ga. = ? amp.       4) 16ga. (12V hot) / 16 ga. = ? amp
2) 12 ga. (12V hot)/ 10 ga. = ? amp.      5) 12 ga. (12V hot) / 10 ga. = ? amp
3) 10 ga. (12V hot) / 10 ga. = ? amp        6) 12 ga. (12V hot) / 12 ga. = ? amp
Appreciate for help/advice.
Platinum - Posts: 13,725
Posted: September 03, 2012 at 10:44 PM / IP Logged
ls2cam
Member - Posts: 8
Posted: September 04, 2012 at 8:43 AM / IP Logged
Give me the calculator/formula to figure out how much the amp from volt and cable length?
new fusebox but on amp. - Last Post -- posted image.
For example:
1) 12 ga. (12V hot)/ 12 ga. = should be 25 amp. @ 3 feet length. Is it correct? It goes to alternator (100AMP) from fuse box.
Posted: September 04, 2012 at 10:19 AM / IP Logged
Look at the chart labeled Power and Ground Cable Specs. It gives you the current rating of each Gauge of wire. 12 Ga wire should be fused at no more than 40 amps. 16 Gauge a maximum of 15 amps.
oldspark
Gold - Posts: 4,913
Posted: September 04, 2012 at 3:53 PM / IP Logged
My method is by formula:
I decide what maximum voltage drop I desire. (Few cable rating tables state that. And if 3V is considered a tolerable voltage drop for a 12V system...)
It's then Ohm's Law (V=IR) where R is the cable resistance per length times the length.
Posted: September 04, 2012 at 8:54 PM / IP Logged
The chart I sent you to is just to show you the maximum safe current of each of the wire sizes. Just do not fuse at a greater current than on that chart.
ls2cam
Member - Posts: 8
Posted: September 06, 2012 at 8:29 AM / IP Logged
Slots:  Slots:
I figured those amps..
1. 25 amp.> goes to ign. switch bat.+
2. 25 amp.> headlight
3. 25 amp.> goes to Alternator
4. 15 amp.> alternator exciter
5. 20 amp.> ign. switch acc.
6. 25 amp.> cool dual fans?
Posted: October 12, 2012 at 12:37 PM / IP Logged
1) at least 50 amps to cover all the ign starter and ACC wires.
2) 20
3)?
4)?
5) see no. 1.
6) Try about 60 for rad fans.
Posted: October 12, 2012 at 12:38 PM / IP Logged
Easier to work out the load on what you're fusing then use the relevant wire gauge.
