dei 530t problem
sicivic13
Member - Posts: 26
Posted: October 08, 2012 at 9:17 PM / IP Logged
Recently added a 530T to my Python 594 system in my 2008 Honda Civic Si. Everything works except when I push the Aux channel to vent the windows. It proceeds to vent them but after a short delay it rolls both windows all the way down even though I did not hold the Aux button. Has anybody encountered this problem before? The dip switches on the 530T are set on the factory setting and Aux Channel 1 is set to validity on the Python.
offroadzj
Gold - Posts: 2,043
Posted: October 08, 2012 at 9:27 PM / IP Logged
Check what you have your aux feature programmed to. It sounds like you have it set for a timed output instead of validity.
Edit: Sorry, it helps if I fully read the post. Put a meter on the negative output of the Python and see if it truly is a validity output or if the negative signal remains after letting go of the button. Then re-check the programming to be sure. Also make sure you are setting the correct aux programming. I thought the aux channels were ch. 4 and 5 but its been a while since I've done a Python.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
sicivic13
Member - Posts: 26
Posted: October 09, 2012 at 7:54 PM / IP Logged
Reprogrammed Aux 1 to validity. Set dip switches on 530T to Low setting which wouldn't even roll the windows up so I changed it back to the Factory setting. Still having the same problem. The Python 594 has 4 Auxiliary channels. Should I be using a different channel? Seems as if the Aux 1 channel is latching even though I programmed it to Validity exactly as the install manual shows.
offroadzj
Gold - Posts: 2,043
Posted: October 09, 2012 at 8:00 PM / IP Logged
what wire do you have connected to the 530 from the remote start module? That will tell you which aux channel you need to program.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
sicivic13
Member - Posts: 26
Posted: October 09, 2012 at 8:03 PM / IP Logged
WHITE/ Violet which according to the install manual is Aux 1 Output.
offroadzj
Gold - Posts: 2,043
Posted: October 09, 2012 at 8:05 PM / IP Logged
Did you put a DMM on the wire to see if it is getting a timed output or validity output on the wire?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
sicivic13
Member - Posts: 26
Posted: October 12, 2012 at 8:34 PM / IP Logged
Tested the wire and it is set to validity. However I discovered that the problem was tied to the remote. Apparently the button wasn't releasing fully and the alarm was seeing it as if I were holding the button down causing the windows to roll all the way down a few seconds later. Thanks offroadzj for all your help. I appreciate it.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
