2006 chevy equinox
oleg1981
Member - Posts: 8
Posted: October 14, 2012 at 1:31 PM / IP Logged
its bad? :( getting thing more complicated?
Platinum - Posts: 7,828
Posted: October 14, 2012 at 2:41 PM / IP Logged
Yes.  It means you need to find a source for an ADS DL or Directed DB-ALL bypass module.  ( Or always start the vehicle before using the aftermarket FOB's to unlock the doors, or only use the Factory FOB's. )  Can't remember if the Factory Alarm goes off with just a remote start.  According to Ready Remote wiring info, the Factory Alarm is Disarmed with Ignition and Passlock2.  Here is a link to the Ready Remote wiring info :
  http://www.readyremote.com/main.asp?action=select&yr=6176&product=Security&make=Chevrolet&model=Equinox
Either way, if the Factory Alarm is ON and you unlock & open the doors with the aftermarket remote start system FOB's, the alarm will go off.  Unless you do the install with a bypass module like the ADS DL flashed with DL GM4 firmware or the Directed DB-ALL flashed with 401.GM5 firmware.
While the Equinox Smokeman1 did recently did not have a Factory Alarm, the DB-ALL w/401.GM5 firmware worked well.
oleg1981
Member - Posts: 8
Posted: October 14, 2012 at 2:49 PM / IP Logged
thanks! will go tomorrow to the idatalink and will post here there answer!
Posted: October 14, 2012 at 3:03 PM / IP Logged
Don't be surprised if iDatalink Headquarters suggests you go to an independent installer that is authorized to use iDatalink products and have it installed by them...   2006 chevy equinox - Page 2 - Last Post -- posted image.
smokeman1
Platinum - Posts: 1,589
Posted: October 15, 2012 at 5:16 PM / IP Logged
Link for rear defrost info if you are going to connect it:
https://www.the12volt.com/installbay/forum_posts.asp?tid=109268&tpn=1&PN=1
There are two lt blue wires back there. It will be the thinner one in the bundle of wire. Mine on the 05 Equinox tested out as Negative pulse.(-)
oleg1981
Member - Posts: 8
Posted: October 19, 2012 at 1:00 PM / IP Logged
so i went there. everething happened exactly like you told! but they doing installs at there place. so they ofered me for very cheap price install! only 450$. LOL.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
