carvox 2300/x6 a system
randyhub
Copper - Posts: 51
Posted: October 21, 2012 at 8:08 PM / IP Logged
Well decided to try an EBay special namely a 105.00 car starter alarm combo because of the features. And while it all looked well and good in the ad but here are a few points to ponder before buying one of these systems.
The Ebay company has ignored my emails asking for help but at least Carvox has a US connection.
http://www.carvox.us/
A few of the systems are 990,999,2300, X6-A.
Now I did pay 250.00 for it to be installed at a Alarm Shop but when I picked up my 2007 Toyota FJ the experience was nothing my friend when he picked up his 2011 Lexus with the Compustar that was installed.
The Compustar programmed up from a PC super accurate and fast not so with my Carvox. :(
The features included proximatity sensor for auto door locks and auto arm and a reported 9000' range.
The range is nowhere near 9000' even with 2 antennas and 433mhz frequency but it is not bad and love the 2 way pager option.
Pointers:
1. Turn off the prox open/close feature as it just messes things up opening and closing this is just not perfected.
2. Turn off all the auto lock features once again causes all kinds of false alarms when arming.
3. Tach the unit how to learn the tach input by starting the car, letting it idle, and press the valt button 5 times until the horn beeps.
4. Remember to save all brain programming form the remote (oh yes you have to do all the programming from little remote icons and do it quick (20 secs) or it kicks you out) by pressing unlock button.
5. For an auto trans gas car I set "01" (ON)  for the following 1-17/18 system options:
1, 2, 3,4,5,6,7,10,11, 12,13,14,15,16,17
8,9, set to "02" (OFF).
As well if your domelight stays on for 20 -30 secs like my FJ you cannot arm the alarm or the siren goes off.
If you try to use to the remote starter I set the crank time to 1.2 secs I would think the tackwire input would overide that need so try it with the default of .6 or 1.2 secs.
If you try to do the * unlock to start the car then try * unlock key to kill the engine the dome lightgoes on and the alarm goes off.
Could not figure why every 3 hours the remote would beep then 15 minutes beep again? Turned out the little exhaust icon was flashing which meant the car starter would start every 3 hours for 24 hours.
 So at point for the cheap price it is pretty good but a programming nightmare due to the manual compared to say a Compustar.
I did buy another remote for 40.00 as I like the larger display so now I have 3 LCD color backlit remotes. Will also be buying another brain as the are like 25.00. :)
Time will tell if it works for any period of time or starts below -40.
Here are some features, lots for 100.00 and many of these systems do not say Carvox but are made by them.
 Hope this help a few as I have spent 2 weeks messing with this system but for 350.00 instaed of 650.00 I will give her a try.
Randy from Calgary Canada
Multi Function alarm:
  • 2 LCD Remotes
  • Remotes color is black
  • Ultra long PLL-FSK communication range
  • Two Way range over 9000 feet (1.7 miles)
  • 3D Digital shock sensor
  • 120db loud siren
  • Starter kill relay
  • Compatible with factory security system
  • Remote query functions
  • Real time clock
  • Real time car/alarm status on LCD display remote
  • Auto arm function
  • Programmable auxiliary output
  • Multiple interfaces for optional sensors
  • Visual, audio and vibration alert remote control
  • Anti-car hijacking system
  • Silent arm/disarm alert
  • Code hopping technology for anti-scanning and anti-grabbing
Advanced Remote Engine Starter:
  • Temperature controlled engine starter
  • Timer controlled engine starter
  • Wireless remote engine starter
  • Turbo mode
  • Gasoline or diesel engines
  • Automatic or manual transmissions
  • Smart gear checking system for remote start
  • Temperature indicated on remote control
Remote Access to Vehicles Functions:
  • PKE- Proximity Keyless Entry- Lock/Unlock doors automatically
  • Automatic window roll up (module required)
  • Remote trunk release
  • Remote engine start
  • Door/Hood/Trunk detection
  • Keyless entry
  • Automatic dome light supervision
  • Turbo mode
  • Professional installation recommended
  • User/installation manual included
randyhub
Copper - Posts: 51
Posted: March 02, 2013 at 8:21 AM / IP Logged
After months of telling myself I can get the Carvox to work I finally decided to put it in the best place.
[IMG]https://i1011.photobucket.com/albums/af233/randyhubair/Garbage_zps40666cdd.jpg[/IMG]
BEWARE of buying these poorly designed/supported systems.
Randy
randyhub
Copper - Posts: 51
Posted: March 02, 2013 at 8:23 AM / IP Logged
tegonfire
Member - Posts: 6
Posted: March 30, 2014 at 9:53 PM / IP Logged
HEy the systeme auto arm/lock each 30 sec...
When I try to change this feature #10 to off mode its bugged and it work 1 time only and go back to on mode alone....
These cheap chinese carvox should'nt be legal...
The shock sensor dont work only if you start kicking many time very very hard the car it may start the shock sensor alarm....
I already had ome alarm that the wind only could start the alarm...
Carvox its scrap and should'nt be installed but crashed.
Aceracer
tegonfire
Member - Posts: 6
Posted: March 30, 2014 at 10:00 PM / IP Logged
Any one know why the feature option are bugged and cannot be changed ???
Aceracer
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
