Unlock Eclipse Radio
jayts95
Copper - Posts: 150
Posted: May 06, 2003 at 6:27 PM / IP Logged
I have a used eclipse radio. I'm not sure what cd unlocks it. Is they any other way to unlick besides sending it out for service?
tdsteele
Silver - Posts: 393
Posted: May 06, 2003 at 7:03 PM / IP Logged
If you have a local Eclipse dealer i would start there. I have an Eclipse deck but i didnt set mine up with that feature, yet anyways. If noone comes up with a good solution for you i plan on stopping by my local dealer either tomorrow or Thursday, I can find out more info then if needed. What model do you have??
dadams312
Member - Posts: 6
Posted: May 06, 2003 at 7:08 PM / IP Logged
The only way to unlock it is with the CD that you chose as the "key".  If that isn't obtainable then you will have to take it to your local Eclipse dealer.
Just make sure it isn't a stolen piece of equipment, the first hint that the local dealer gets that it might be stolen they will send it off to Eclipse...Eclipse will then be able to decide if it was stolen or not.  At that point Eclipse will send the unit back to your local dealer, and your dealer will call you up saying it's ready to be picked up, you will then be greeted by the police.
bberman1
Gold - Posts: 2,314
Might want to read this post from a while back https://www.the12volt.com/installbay/forum_posts.asp?tid=6498&KW=cd+eclipse but most likely you will need to send it in to Eclipse to have it reset, they charge $45
