remote start resistors
scottie31
Posted: November 22, 2012 at 6:53 PM / IP Logged
I'm going to attempt to install a remote car starter this weekend on my 2004 Dodge Caravan.  I was looking at the required resistors that were posed in the wiring instructions that I found on this site and was wondering if I can use any other resistors without causing any issues.
5.3k ohm resistor - I have a 4.7k or 5.6k
2.1k ohm resistor - I have a 1.8k or 2.2k
1.69k ohn resistor - I have a 1.5k or 1.8k
Any help with this would be appreciated,
Thanks!
Platinum - Posts: 7,828
Posted: November 22, 2012 at 7:22 PM / IP Logged
If you have a nice assortment of resistors, you can use two or more in series or parallel to create the exact
value you need.  Resistors in series will just add together.  100 ohms plus 470 ohms = 570 ohms
Resistors in parallel use a formula which can be found at this link :  http://www.sengpielaudio.com/calculator-paralresist.htm
It is best to have a DMM to check and verify the resistors and the results ( unless you know the color code, something about
Bad Boys and Young Girls...  remote start resistors - Last Post -- posted image.  ).
Looks like you need :
 180 ohm for the Starter Mux
 2K ohm and 5.2K ohm ( or 5.3K ) for door locks
 1.5K ohm and 2.7K ohm for sliding doors    Diagram      http://documents.audiovox.com/700078.pdf
 2K ohm ( or 2.1K ) for Parking Lights
 1.7k ( or 4.7K ) ohm for Hatch Release
And a bunch of relays...  Think I did a 2006 Caravan with resistors and a Key-In-The-Box a long time ago.
soundnsecurity
Gold - Posts: 2,720
Posted: November 22, 2012 at 7:41 PM / IP Logged
you normally dont have to be exact when using resistors, i think if you can be within 5%-10% of the value that it calls for then it will work perfectly. the only set listed that you might have a problem with is the first set, 4.7k or 5.6k might be too far off from 5.3k. you will probably end up using a few different resistors together in series. if you use three of your 1.8K resistors then you should be right at what you need.
KPierson
Platinum - Posts: 3,527
Posted: November 22, 2012 at 11:59 PM / IP Logged
Big Boys R*pe Our Young Girls But Violet Gives Willingly
Black, Brown, Red, Orange, Yellow, Green, Blue, Violet, Gray, White.
0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Kevin Pierson
Posted: November 23, 2012 at 2:43 AM / IP Logged
I feel a terrible pun afflicting me.
Change the third word to "resist".
KPierson
Posted: November 23, 2012 at 7:10 AM / IP Logged
I was "taught" that saying in 7th grade. The teacher actually left the room so a kid in the class could recite it to us. A questionable teaching technique but it obviously worked! I never forgot it. Probably one of few things I still remember from back then!
Kevin Pierson
tommy...
Gold - Posts: 1,901
Posted: November 23, 2012 at 8:50 AM / IP Logged
Are you using relays or an actual Remote Start...? If doing a normal r/s... the bypass does most of that for you(Resistors)... Other-wise, Good-Luck...!
M.E.C.P & First-Class
Posted: November 23, 2012 at 12:06 PM / IP Logged
Our 12 year old giggle in Science class was Virgins Are Rare.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
