2011 juke, remote starter
ironsides
Posted: December 16, 2012 at 11:38 AM / IP Logged
I'm in the planning stages of putting a remote starter into my Nissan Juke. My Juke has the push-to-start ignition, and is an automatic. I've ordered a Viper VSS3000 remote starter, a DB-ALL bypass, and an XKLoader2 to program the DB-ALL. I'm going to connect the remote starter to the bypass with D2D. I was planning on using the NISS4HT 1.07 firmware in the DB-ALL. The install guide for it is here. The install guide doesn't show what wires I have to connect between the remote starter and the vehicle, would it just be starter, ignition, and accessory wires? I'm not sure about programming Key2Go, it seems like only installers will be able to do that, is that true?
Would I be better off getting an ADS-AL CA instead of the DB-ALL? Their installation guide seems more detailed. I'm mainly looking to remote start the car with the factory remotes, and to just get in and go when the car has been remote started. The DB-ALL with the NISS4HT firmware seems to offer that, does the ADS-AL CA?
Lastly, can anyone tell me where the immobilizer connector is in the Juke? I know where all the other connectors are.
Thanks.
ironsides
Posted: December 16, 2012 at 12:14 PM / IP Logged
Sorry, obviously I mean 2011 Juke
Platinum - Posts: 7,827
Posted: December 16, 2012 at 2:57 PM / IP Logged
The immobilizer connector is behind the PTS button.
The iDatalink ADS solution requires KLON programming and is only available to registered iDatalink dealers.
Here is a link to the Fortin EVO-ALL solution for your car :  https://ifar.ca/download/6711/preview.html
ironsides
Posted: December 17, 2012 at 11:04 AM / IP Logged
There is a local shop that will program the iDatalink ADS-AL CA for me for $25. I'm returning the DB-ALL. Thanks.
Friday, November 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
