1995 jaguar xj6 wiring colors incorrect
dfries
Posted: January 10, 2013 at 2:11 PM / IP Logged
The wiring colors on 12volt.com are different than what is installed in the car...
There are NO white cables, but several with grey/other color. The only one I can identify is the ground/black.
the12volt
Administrator - Posts: 3,957
Posted: January 10, 2013 at 2:16 PM / IP Logged
It is not uncommon for wiring to be different in the same model year. Follow the link below, then post your results here, and we'll add your info to our database.
https://www.the12volt.com/installbay/forum_posts.asp?tid=74637&PN=1
1995 jaguar xj6 wiring colors incorrect - Last Post -- posted image. the12volt • Support the12volt.com
KPierson
Platinum - Posts: 3,527
Posted: January 10, 2013 at 6:31 PM / IP Logged
This is why it is so important to TEST EVERY WIRE before making any connections. Wiring guides are often wrong. Manufacturers change specs throughout the model year, different trim levels get different wiring, cars made for different geographic regions get different wiring, etc. A guide is simply that, a guide.
Kevin Pierson
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
