door triggers
mbee1
Member - Posts: 23
Posted: February 21, 2013 at 12:25 PM / IP Logged
asking for help on this project. installing a aps-25c and im having trouble with door triggers on this vehicle. only reading drivers door not the three others. figured out my problem on the door lock actuators, now im stuck on door trigger. open drivers door alarm goes off, but wont on any other door. brown wire from alarm to the grey plug pin#23 tan wire. dash reads when any door is open and im lost on what im missing here. also no parking light, white wire from alarm to lt blue wire pin#8. i think im getting stressed and missing a simple step. thanks for any help...
12/12 GMC savana cargo van with aps-25c
offroadzj
Gold - Posts: 2,043
Posted: February 21, 2013 at 1:06 PM / IP Logged
Ready remote shows this for the door trigger:
Door Trigger      gray/black (ajar); tan (open)      -      BCM, pink plug, pin 10; gray plug, pin 23
Notes: The BCM (Body Control Module) is under the passenger dash.
Maybe try seeing what the gray/black wire reads with each door open?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
mbee1
Member - Posts: 23
Posted: February 21, 2013 at 2:32 PM / IP Logged
same thing, only drivers door. instead of white wire from alarm, i used purple to trigger the dome light(+) to activate alarm. so know any door turns on dome light and its triggered.
offroadzj
Gold - Posts: 2,043
Posted: February 21, 2013 at 3:06 PM / IP Logged
Yup, that should work fine. The only thing you have to remember is that the alarm will not be active for the doors until the dome light shuts off.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Mike M2
Platinum - Posts: 2,652
Posted: February 21, 2013 at 3:30 PM / IP Logged
I thought that if you use the dome wire positive on this van they won't work if you turn off the domelight at the switch? Might want to check.
Here's from Directechs...
left Front Door Triggergray/black (ajar); tan (open)-BCM, pink plug, pin 10; gray plug, pin 23
Right Front Door Triggertan/white-BCM, pink plug, pin 8
Left Rear Door Triggerdk. blue/white-BCM, pink plug, pin 15
Right Rear Door Triggeryellow/black-BCM, pink plug, pin 14
Dome Supervisiongray/black or dk. blue/white+BCM, white plug, pin 5
Trunk/Hatch Pinpink/black-
BCM, pink plug, pin 12
Mike M2
Tech Manager
CS Dealer Services
offroadzj
Gold - Posts: 2,043
Posted: February 21, 2013 at 3:55 PM / IP Logged
And that is exactly why I wish I could get Directechs access again... but the purchase requirements to get access are next to impossible for a small shop like mine to do.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
mbee1
Member - Posts: 23
Posted: February 22, 2013 at 7:57 AM / IP Logged
yes , alarm wont activate untill dome light shuts off. lucky for me customer likes it. he was just happy that i installed power door lock on the vech. its his work van and the main problem he had was no door locks. thanks for everyones help.
offroadzj
Gold - Posts: 2,043
Posted: February 22, 2013 at 8:58 AM / IP Logged
As Mike posted, test to make sure they work with the dome light turned off. The domelight wire may not be active if it is turned off and therefore would not trigger the alarm.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
