first time wiring, viper 5704, 1996 toyota t100
lostcircuit1
Member - Posts: 10
Posted: March 02, 2013 at 12:34 PM / IP Logged
howieII Thanks a lot for your help.I think that I only need to make you two more questions before starting 1st is: in the 10-pin heavy gauge connector the H3/1 pink (+) ignition 1 input/output and H3/6 red (+)fused (30A) ignition input, can this two guys go connected together? or how do I connect them? I'm confused in those. Question 2nd do I need Relays for this basic installation? I think after this I'll be able to start. (thank you one more time.)
smokeman1
Platinum - Posts: 1,589
Posted: March 02, 2013 at 12:49 PM / IP Logged
I listed the H3 connector for you already.  H3/1 Pink goes to ignition 1 of your truck.. H3/6 Red goes to constant 12 volts on your truck.  Red is input and the H3/1 Pink is Output to your ignition wire.
