1999 lesabre vats
naviracer23
Member - Posts: 11
Posted: February 28, 2013 at 10:05 PM / IP Logged
Im doing a compustar remote starter/idatalink bypassed remote starter on a 1999 Remote Starter and have everything connected but the yellow wire from the bypass to the vats wire...Whic vats wire do I connect it to and were can I access it as I cannot get the steering column cover off....
Platinum - Posts: 7,827
Posted: March 01, 2013 at 1:30 AM / IP Logged
As noted in the iDatalink install guide, the VATS wires you are looking are in a Gray or Orange 1/8" diameter tube that
runs from the steering column towards the fuse box under the dash .  You will find it along with the other ignition wires
once you drop the under dash trim panel.
The VATS wires inside are very small gauge, the same color & gauge and slightly difficult to work with.  The iDatalink
install guide shows which wire to connect to by a ground or votage check using a Digital Multi Meter.
Wednesday, January 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
