avital 4003l sets off viper alarm
elninoloco7
Member - Posts: 13
Posted: March 12, 2013 at 10:14 PM / IP Logged
My car has no factory alarm but i did install the Viper 3203 a while back(2 way keyless entry/alarm with optional remote start). That optional remote start is with the Avital 4003l, a separate brain.
Installation went smoothly, and everything works as it should, EXCEPT, for one thing. I can remote start with the Viper 3203 keyfob (as it has a remote start Icon on it) and it works, however, when i Remote Start with the Viper Armed, my alarm sets off.
Now i know on the Avital there is a "Factory Disarm" wire that wires up to a factory alarm to disarm OEM system to prevent horn from going off. In my case i have a Viper alarm, do i still use the "Factory Disarm" wire from the Avital to the Viper; if so what wire do i tap it in, in the Viper 3203? If not what has to be done?
avital 4003l sets off viper alarm - Last Post -- posted image.
dasbogie
Silver - Posts: 514
Posted: March 13, 2013 at 2:36 AM / IP Logged
you need to remove the viper ignition input which is yellow from the vehicles ignition wire and solder it to the avitals yellow ignition input.
Advanced
elninoloco7
Member - Posts: 13
Posted: March 15, 2013 at 10:11 AM / IP Logged
Great, the seem to have done the trick. Thanks.
dare_ds69
Silver - Posts: 419
Posted: April 02, 2013 at 1:25 PM / IP Logged
also make sure the shock sensor is not too sensitive
how own your mind, control your life.
MECP certified. always use a DMM
Thursday, November 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
