diode isolate.
patrickmac888
Posted: April 14, 2013 at 5:58 PM / IP Logged
Im confused on how to diode isolate 2 (+) parking light output wires. one coming from aftermarket alarm and one coming from remote starter. I also need to connect them on a SPDT relay. Thanks in advance
tonanzith
Gold - Posts: 603
Posted: April 14, 2013 at 8:14 PM / IP Logged
I need more specfics. What alarm/remote start. What vehicle. And typically a diode isn't needed if using a relay.
Gary Sather
Posted: April 16, 2013 at 12:02 AM / IP Logged
You don't have to. Just join making sure they polarity is the same, if the vehicle spec calls for NEG (-) make sure they're both neg, ditto for POS (+).
patrickmac888
Posted: April 16, 2013 at 7:12 PM / IP Logged
Thanks for response.
2007 Toyota Corolla CE
Alarm - Omega Excal-500
Remote - Bulldogsecurity RS83B with built in bypass module.
thanks again.
patrickmac888
Posted: April 16, 2013 at 7:17 PM / IP Logged
Thanks for response. Do i need to tap in from the alarm or remote starter's output wire? or tap in to the SPDT relay's wire? Im just gonna use a squeeze tap connector.
One more thing, will it break if I use both the negative and positive parking light wires? right now im using the negative for the alarm.
thanks again
Posted: April 16, 2013 at 11:26 PM / IP Logged
Show us your circuit, I don't understand the question.
Squeeze tap?
Forget it; just wrong in so many ways.
