03 ford focus se wagon
dardack
Posted: April 30, 2013 at 8:22 PM / IP Logged
I'm trying to find the tach wire for an after market cruise control. Please assist if possible.
Also is the information for the WHITE/ green VSS to radio valid for this car or where else is the VSS located?
Platinum - Posts: 13,725
Posted: April 30, 2013 at 10:11 PM / IP Logged
     Tachometer BLACK/ ORANGE (AC) AT IGNITION COIL
     Speed Sense YELLOW/RED (-) AT ABS HYDRAULIC UNIT ON DRIVERS SIDE FIREWALL UNDER HOOD
Tach may be BLACK/ Green at the coil.
dardack
Posted: May 01, 2013 at 6:11 AM / IP Logged
Thank you for info.
So both are on the engine side of the bulkhead/firewall? (sorry i fix my cars all the time but i'm terrible with the proper words for things)
Very much appreciated.
Posted: May 01, 2013 at 1:28 PM / IP Logged
You should also get the VSS wire at the gearbox, although on 03 models it was WHITE/ green on a radio plug (yellow in the middle if I remember).
The wiring colours were the same as here in those years.
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
