powerfist brand wireless remote kit
quintenrc
Posted: May 19, 2013 at 9:09 PM / IP Logged
I have a 1993 Dodge Grand Caravan ES, and I picked up this kit @ Princess Auto, PowerFist part #8003441. (I was feeling impulsive and it was on sale.) All I want from it is Remote Keyless Entry and Trunk Release. Through testing I have surmised that the door lock system is a 3 wire positive, and trunk release is 1 wire positive. My question is: Where would be the best place to get fused 12V+ from for terminals 85,87 (lock relay) and 86,87 (unlock relay)and does it need to be constant? I am going by the 3 wire positive lock diagram I found on this site, which seems to apply as this PowerFist units' internal relays are only 15A and it didn't work when I hooked it up without the extra relays. (I can hear the internal click of the units' relay, but there's no actual locky-unlocky) This is my first install of this type and I just want to be sure before I go balls-deep with it. Any additional tips or input gladly welcomed.
free admission, pay at the door--pull up a chair, and sit on the floor.
Posted: May 19, 2013 at 10:18 PM / IP Logged
Don't know what you are doing wrong but but 15 amp internal relays would be more than powerful enough, you're only triggering existing relays. (120 mAmps).
You're looking for a POS output on your lock wires to trigger the existing relays.
This is a typical pos trunk release set-up:- C86_trunk_release.bmp
The fuse box input and yes it has to be a constant.
And no you mean 86 and 87 NOT 85 and 87.
Posted: May 19, 2013 at 10:21 PM / IP Logged
This should be your lock outputs on your unit, never heard of it which should tell you something.
30 = Common
87a = NC
87 = NO
86 = coil +
85 = coil -
Since 85 and 86 are internal ASSUMING internal relays, your unit should have 6 lock wires.
quintenrc
Posted: May 19, 2013 at 11:28 PM / IP Logged
Thanks for the prompt reply! This is the unit and the instructions that came with it. When I tested it, I had used one wire from Grey and one wire from Brown (Channels 1 and 2) hooked to the lock/unlock wires coming out of the drivers side power lock switch. The other wire from each channel was grounded. Am I just hooking in at the wrong place in the circuit? [IMG]uploads/p5190487.jpg[/IMG][IMG]uploads/p5190489.jpg[/IMG]
quintenrc
Posted: May 19, 2013 at 11:30 PM / IP Logged
ffs...I don't think my upload worked.. I will try to get those images on here
quintenrc
Posted: May 19, 2013 at 11:41 PM / IP Logged
powerfist brand wireless remote kit - Last Post -- posted image.
